Kz440 cdi box problem
  • Motl
  • Motl's Avatar Topic Author
23 Jun 2016 11:06 - 23 Jun 2016 12:46
#732529
Hi guys. Newby here.
I fried my cdi box and it is sh347 type transistor ignitor but with 6 wires. Trying to find a spare one over ebay but all I can find is cdi box with 5 wires. I'm attaching an image.
Does anyone know what is that 6th wire for and will the cdi box with 5 wires work on my motorcycle.
Thank you in advance.
Attachment IMG_20160623_182710.jpg not found
Last edit: 23 Jun 2016 12:46 by Motl.
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: Kz440 cdi box problem
23 Jun 2016 19:26
#732562
KZs never had Captive Discharge Ignitions.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • Motl
24 Jun 2016 00:23
#732581
Thx man, but what do you think why mine does ha ve. Will it be safe to mount a unit without that 6th wire?
  • Nebr_Rex
  • Nebr_Rex's Avatar
24 Jun 2016 05:12
#732600
That single wire looks to be just a ground wire. Just ground it.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
  • loudhvx
  • loudhvx's Avatar
24 Jun 2016 05:18 - 24 Jun 2016 05:20
#732602
I can't find a diagram using the brown/white wire on a 440. What year?
It is most likely an interlock safety wire. Usually it needs to be grounded to enable the igniter. So like NebrRex said, it probably needs to be grounded. The igniter connection, that is, needs to be grounded. Don't ground the harness side of the brn/wht wire.
If you can only find the 5-wire version, you can probably use it, and just ignore the brn/wht wire on the harness, and leave it unconnected.
Last edit: 24 Jun 2016 05:20 by loudhvx.
