1981 kz550c1 electrical help needed!
- smurfkoolaid
17 Jun 2016 12:00
I bought this bike awhile back, striped everything from the frame so i could drop the seat. I took photos of all the electrical very indepth but that was about a year and a broken cellphone ago. so now that the engine is done and everything is put back together. I'm stuck with a mess of wires. yes i have a book. yes i have a diagram off of kz rider as well. but some of these wires just are not making sense. mostly the grounding wires. I will add some photos in a bit
Black and yellow wire that splits off into 3 other black and yellow wires. towards the back of the bike (maybe to each brake light?)
yellow with black stiped wire with double crimp opening. back of bike as well.
ill add photos in a bit. thanks for anyhelp. I'm trying to get this done and out!
Re: 1981 kz550c1 electrical help needed!
17 Jun 2016 12:12
Perhaps blk/yel connections to ground the rear bulb and grounds for each blinker light.
Should be shown on the wiring diagram.
17 Jun 2016 12:24smurfkoolaid wrote: . . . yes i have a diagram off of kz rider as well. but some of these wires just are not making sense. mostly the grounding wires. . . .
This wiring diagram from the KZr FILEBASE seems to clearly show the rearward black/yellow wire ground connections.
Click here > kzrider.com/jdownloads/Fours/KZ550/KZ550-Electrical/Z550C1.pdf
- smurfkoolaid
17 Jun 2016 12:56 - 17 Jun 2016 13:03Attachment DSCN0046(1).JPG not found
a couple photos.
Last edit: 17 Jun 2016 13:03 by smurfkoolaid.
- smurfkoolaid
17 Jun 2016 13:08Attachment DSCN0048(1).JPG not found
Attachment DSCN0047(1).JPG not found
