Speedo dash light?
  • JoHNY
  • JoHNY's Avatar Topic Author
Speedo dash light?
16 Jun 2016 02:47 - 16 Jun 2016 03:23
#731613
I'm fitting a single speedo to my 82 KZ. The standard dash has two turn signal lights, the speedo I've fitted only has one LED light. Question is how can I make both turn signal sides light the one dash light. If I try and feed the single unit wires to each turn signal both turn signal sides light at the same time. I have tried taking a feed from the flasher unit, no joy.
someone suggested fitting a diode on each feed, would this work, any idea what kind of diodes I'd need?
Kawasaki Z750P7 Spectre, Triumph Daytona 955i, Honda CBR1000FN
Last edit: 16 Jun 2016 03:23 by JoHNY.
  • bountyhunter
  • bountyhunter's Avatar
Re: Speedo dash light?
16 Jun 2016 15:41
#731675
Typical dash lights are about 4W which is 0.3A on a 12V line so a 1A diode should be enough. A 1N4001 diode should work, you can get them at any electronics shop probably Fry's has them in their parts area.
  • JoHNY
17 Jun 2016 06:07
#731733
Cheers buddy, bought two diodes and got it work perfectly :)
