Ignition for81 KZ1000J
  • Zubes21
  • Zubes21's Avatar Topic Author
04 Jun 2016 18:23
#730070
Hello gang, wonder if some of you have some recommendations for me here. It seems I have a bit of an ignition issue with my 1981 KZ1000J.
It has been recommended that I purchase a Dyna S ignition system. Does anyone have any experience with this and and suggestions? Should I change out Coils and ignition complete? The bike is primarily stock with a Hindle Header and has been rejetted.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Ignition for81 KZ1000J
04 Jun 2016 18:47
#730077
I have the Dyna and 3 OHM coils. Works great. If yours is a electronic ignition, you will have to change coils too.
  • Zubes21
04 Jun 2016 19:02
#730087
Yes mine is electronic ignition - my mechanic is saying go NOS OEM....not aftermarket coils....did you go with Dyna Coils?
  • SWest
  • SWest's Avatar
  • 10 22 2014
04 Jun 2016 19:12
#730090
I had stock coils. Got a good deal for the 3 OHM Dyna's. Good thing about this set up is, parts are available.
  • Nebr_Rex
  • Nebr_Rex's Avatar
04 Jun 2016 19:37
#730096
The stock electronic ignition is very reliable. And it draws fewer amps than a Dyna.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • martin_csr
  • martin_csr's Avatar
05 Jun 2016 05:00 - 05 Jun 2016 05:24
#730133
I'd guess the weak link is the stock coils. you can probably use either the grey Dyna 2.2 ohm or the green 3.0 ohm. I think the 2.2 ohm are supposed to be a better match for the stock igniter. Accel is another brand. or possibly the coils from a Buick Grand National (source = elr658 over at kaw.mc.org. he's one of the more knowledgeable Kaw guys outside of KZR).
by elr658: my very fast KZ1000R1 has Grand National coils as does my fast cb1100 as does my slow 79 cb750f.
.............. ... Buick, six cylinder, black, world's fastest living room, adapt the little wires to your bike.
Last edit: 05 Jun 2016 05:24 by martin_csr.
