spark
- dan424
- dan424
Re: spark
02 Jun 2016 18:05
i have an 83 kz550 and i am not getting any spark. any suggestions?
Re: spark
02 Jun 2016 18:09
Get some.
Re: spark
02 Jun 2016 18:12
Welcome, Pics? Do you have a manual?
Re: spark
02 Jun 2016 18:16
Seriously, there are several possibilities.
The kill switch is in the off position.
The battery is too weak to turn the starter and fire the ignition.
There could be a loose or broken wire somewhere in the ignition system.
The safety switch on the clutch lever is malfunctioning .
The igniter is fried.
It would help us if you could provide some additional information.
Has the bike run since you bought it? If so, what has happened or what has been done to the bike since the last time it ran? How do you know it is not making spark?
- dan424
- dan424
Re: spark
02 Jun 2016 18:24
WAS RUNNING FINE. PUT 100 MILES ON IN 2 DAYS. THEN JUST DIED.HOOKED UPTO BATTERY CHARGER TO JUMP IT'PLENTY OF CRANKING POWER. PUTA SPARK TESTER ON COUPLE OF PLUGS AND NO LIGHT LIT UP
Re: spark
02 Jun 2016 20:47
A battery charger does not provide enough amperage to start the bike. If you do not have one of the more expensive chargers that can detect the health of the battery, the best thing to do is to take the battery to an auto parts store or motorcycle repair shop that can load test it to be sure of its health. Even with a couple of dead cells, it can fool a simple volt meter.
Once you are sure the battery is up to snuff, you can begin chancing down other possibilities.
You did check the kill switch, right?
The following user(s) said Thank You: dan424
- dan424
Re: spark
03 Jun 2016 11:22 - 03 Jun 2016 12:08
no the kill switch has always been on run.i got bike from my roommate he rode it all last summer.i had replaced the pick-up coil,that i got off a 750,and was running good until it just died.i appreciate your advice. just put a circuit tester on switch seems ok
Last edit: 03 Jun 2016 12:08 by dan424. Reason: additional research
Re: spark
03 Jun 2016 15:25
Do NOT try to start the bike with a battery charger hooked up or with the bike jumpered to another vehicle whose engine is running (hopefully you have not damaged anything yet). Doing that can fry your bike's electrical system. If your battery is run down charge it up; if it is bad replace it. Ed
- dan424
Re: spark
04 Jun 2016 13:55
no i haven't jumped it off a running vehicle. i charged battery which was reading charged anyway
- mopguy
Re: spark
04 Jun 2016 15:31 - 04 Jun 2016 15:32
Once battery is charged see if coils are getting 12 V, if yes, test coils with ohmeter, if coils are good, test spark plug wire, might want to cut a bit at both ends and reassemble, wire are good, check caps, finally check plugs. somewhere along there you might find what you are looking for.
Last edit: 04 Jun 2016 15:32 by mopguy.
