KZ650 elctronic ignition coil replacements
  • outbackjimnt
  • outbackjimnt's Avatar Topic Author
02 Jun 2016 05:23
#729616
No eBay APP ID and/or Cert ID defined in Kunena configurationHi all
Can anybody tell me if these would be appropriate for my '81 KZ650-D4 (SR) with electronic ignition (not points)?
The OEM TEC ZC006-TR12V originals were dead and I obtained another used pair with the following resistance measurements:-
Primary windings (spec 1.8 - 2.7 ohms)
1&4 - 2.0 ohms
2&3 - 1.9 ohms
Secondary windings (spec 12K - 18K ohms)
1&4 - 11.1K ohms
2&3 - 10.9K ohms
I don't believe I am getting a good spark as she idles too rich until she stalls. That's my thought based on the primary resistance readings.OEM TEC ZC006-TR12V
Jim
  • TexasKZ
  • TexasKZ's Avatar
Re: KZ650 elctronic ignition coil replacements
02 Jun 2016 05:44
#729620
These should work as well, and you can get a matched pair.
www.z1enterprises.com/product/DYDC4-1
  • z1kzonly
  • z1kzonly's Avatar
02 Jun 2016 06:43
#729635
No eBay APP ID and/or Cert ID defined in Kunena configurationCheap set of Factory 1000 should be same as 650.
  • SWest
  • SWest's Avatar
  • 10 22 2014
02 Jun 2016 07:50
#729651
As I said in the other thread, I'd verify if it's the coils or the igniter. If you buy new coils for it, you are stuck with the igniter system. If it's bad you have to start all over again. :unsure:
