Legacy Wires? 83 KZ550
  • Kirkpatrick
  • Kirkpatrick's Avatar Topic Author
29 May 2016 16:38 - 29 May 2016 17:26
#729131
I have two wires in the battery area that are just there. They do not have the same male/female to connect to each other and they are pretty beefy and appear to be stock. Any idea on what they are for? Thanks, Brendan
1983 Kawasaki KZ550
1983 Suzuki GS1100ED
1982 Suzuki SZ1000 (Katana)
1997 Honda CR500
Last edit: 29 May 2016 17:26 by Kirkpatrick. Reason: info
  • martin_csr
  • martin_csr's Avatar
Re: Legacy Wires? 83 KZ550
29 May 2016 18:21 - 29 May 2016 18:26
#729157
The white/black wire might be a pos (+) accessory lead from the accessory fuse box.
The black/yellow would be a accessory ground wire, but I don't know if that's stock.
The acc ground on my 81 650 is connected at the neg (-) battery terminal.
Also, there are probably a couple of acc leads at the headlight bucket. blue/white pos (+) & black/yellow ground. the blue/white wire is from the same fuse box as the white/black pos (+) acc & each has a 10A fuse.
Last edit: 29 May 2016 18:26 by martin_csr.
  • Kirkpatrick
29 May 2016 21:43
#729186
Both are wrapped up in the same loom and tape as the other wires and look to be somewhat stock. I will throw a volt meter on them tomorrow. Thanks, Brendan
1983 Kawasaki KZ550
1997 Honda CR500
