dyna coils
  • dvjoiner
  • dvjoiner's Avatar Topic Author
dyna coils
13 May 2016 06:30
#726106
I was thinking can dyna 3ohm dual output coil from a harley work an a 94 kz1000 p
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: dyna coils
13 May 2016 06:33 - 13 May 2016 06:38
#726107
No eBay APP ID and/or Cert ID defined in Kunena configurationWhy not replace both for $140 new?
Last edit: 13 May 2016 06:38 by SWest.
Re: dyna coils
13 May 2016 06:56
#726113
dvjoiner wrote: I was thinking can dyna 3ohm dual output coil from a harley work an a 94 kz1000 p
Yes, I would think so, as far as the basic coil function is concerned.
Will require other secondary loop components that are serviceable and suitable to the application such as plug wires of correct type (preferable solid core) and sufficient length, and spark plug caps (preferably with zero resistance).
Good Fortune! :)
