Kz550 brake switch?
  • nickleo373
  • nickleo373's Avatar Topic Author
Kz550 brake switch?
04 May 2016 13:00
#724539
Hey everyone
My 1981 kz550's brake light on the tach has been flashing for a while now. Ive narrowed the problem down to a rectangular shaped brake sensor of some sort behind the left side cover. I'm trying to find the part on ebay to get another but I'm not sure what its called to look it up. Does anyone know the name of the part?
1981 KZ550C LTD
"If you ain't first, you're last"
Re: Kz550 brake switch?
04 May 2016 13:04
#724541
Take a look at the diagram in the link below. Does the part in question look like any on that chart? Ed
www.powersportswarehouse.com/p/Kawasaki#...50-C2-1981/080122F-3
  • nickleo373
04 May 2016 13:17
#724545
Attachment image-2.jpeg not found
I believe it's the outage indicator switch. Thanks Ed
1981 KZ550C LTD
  • martin_csr
  • martin_csr's Avatar
04 May 2016 15:18 - 04 May 2016 15:19
#724570
Maybe the problem is that switch, but I think the flashing brake warning light means the outage indicator switch is working & it is warning you that the brake light circuit or the brake light itself is defective. It could be as simple as a bad brake light bulb. or maybe the wrong bulb was installed. or maybe an LED. ???
Last edit: 04 May 2016 15:19 by martin_csr.
  • nickleo373
04 May 2016 15:21
#724571
The brake light is functioning as it should with an original bulb. The light will shut off if I'm able to jiggle the outage switch to the right angle. The vibrations from the the engine always nudge it out of place causing the warning light to flash
1981 KZ550C LTD
  • martin_csr
04 May 2016 15:34 - 05 May 2016 07:16
#724576
My mistake then. You've probably already checked, but I would remove the plastic connector & examine the terminal pins & wires, in case one of them is damaged or worn or something. or the wire cover could be hiding some wire damage. ???
and also check the wire harness connector & pins n stuff.
Last edit: 05 May 2016 07:16 by martin_csr.
  • nickleo373
04 May 2016 15:41
#724578
I'll check the wires before ordering a new switch. Thanks for the help
1981 KZ550C LTD
