Need simplified harness
  • Neut223
  • Neut223's Avatar Topic Author
26 Apr 2016 07:39
#723025
Looking to see if someone can make me a simplified harness new. Anyone willing to make me one? 1974 kz400.
  • loudhvx
  • loudhvx's Avatar
Re: Need simplified harness
26 Apr 2016 08:26 - 26 Apr 2016 08:27
#723038
It's much easier to make it on the bike, rather than try to make one off the bike and then force it to fit the frame.
Are you able to solder? To make a bare bones harness is not too hard as long as you get a good ratcheting crimper and automatic stripper. Figure on about $100, or little over, including tools, wire, non-adhesive tape, zip ties, spade lugs and other supplies.
The first time, it may take a couple days to get everything right (with some re-doing and routing changes, etc.).
Last edit: 26 Apr 2016 08:27 by loudhvx.
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
26 Apr 2016 08:30
#723040
If you don't know anything about electrical systems I'd highly recommend leaving the harness stock and unmolested. That way you can reference the FSM with any issues.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • davido
  • davido's Avatar
26 Apr 2016 09:19
#723052
Im busy with my harness at the minute ( first time). Ive got the whole thing pegged out on a plank of wood. The plan is to get everything working as it should,all the lights,switches etc,Fix any problems on the kitchen table. Then to strip off the wrapping and make a copy with new wire and connectors.
I thought about making a simplified custom jobby but,to be honest,I dont understand it well enough to know what I can and cannot do without and everything is there for a reason anyway. Ok maybe I dont need hazard lights but if theyre there,why not keep them?
It was the best way I could think of for a novice to build a new harness which will,hopefully,be reliable and last another 35years.
If you do want to go custom, Bikexif have a nice tutorial on the basics.It might be something for you;
www.bikeexif.com/motorcycle-wiring
Good luck,hope it works out for you.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • loudhvx
  • loudhvx's Avatar
26 Apr 2016 10:12
#723064
I can draw a bare bones schematic for you if needed. Follow my links to the Mattylight thread to see some examples.
  • Gregl
  • Gregl's Avatar
26 Apr 2016 17:37
#723138
dude ur amazing. thank you very much.
davido wrote: Im busy with my harness at the minute ( first time). Ive got the whole thing pegged out on a plank of wood. The plan is to get everything working as it should,all the lights,switches etc,Fix any problems on the kitchen table. Then to strip off the wrapping and make a copy with new wire and connectors.
