kz550 b2 coil resistance?
  • zirafin
  • zirafin's Avatar Topic Author
05 Apr 2016 05:24 - 05 Apr 2016 05:28
#719340
halo i try to find info on manual but its not acuate for me :( i want to know if its good parts o bad.
1. coils in my first picture i check the resistance on coil + an - its 2.6 and other coil is 2.5 ohm-- its ok ??? ORE bad?
Attachment IMAG1342.jpg not found
Attachment IMAG1343-2.jpg not found
2. coils spark wires the 3 pictures ,resistance on 1 and 4 cylinder wires = 21.5 and on 2-3 cylinder its 21.5 ohm-- its ok ore bad??
Attachment IMAG1344-2.jpg not found
3. picup coils i tested like in manual :
Remove the right-hand side cover and
disconnect the 4-pole pickup coil connector
(Figure 20).
2. With an ohmmeter set at Rx100, measure
the resistance between the 2 pairs of leads:
black and blue (No. 1 and 4) and yellow and
red (No. 2 and 3). The resistance should be
400-500 ohms.
i have 424 and 431 so it s ok.
Attachment IMAG1346.jpg not found
Last edit: 05 Apr 2016 05:28 by zirafin.
  • zirafin
Re: kz550 b2 coil resistance?
05 Apr 2016 05:32
#719341
and wires from coil to spark plug i tested to its resistance all diferent :
5.12
4.72
4.82
4.95
Attachment IMAG1338.jpg not found
  • loudhvx
  • loudhvx's Avatar
05 Apr 2016 08:09
#719361
Each plug cap has a resistor. Each should be around 4 to 6 k typically, but I don't know the actual spec. It should be in the manual.
Each wire is copper/zinc plated steel, so the wire, itself, should be near 0 ohms. (But you still have the caps attached.)
The high tension side of the coils will be 11k ohm to 13k ohm, typically, but I don't know the actual spec. It should be in the manual.
The primary side of each coil should be around 2.3 to 2.6 ohms, typically, but the manual gives a range centered on 2.3.
Either way, they look to be old, and passing resistance checks does not confirm a coil is good.
05 Apr 2016 21:40
#719470
The resistance readings look okay to me.
As noted by loudhvx, passing resistance checks does not confirm a coil is good.
My understanding is that a resistance check can show a shorted or open winding inside the coil, but does not test for possible high voltage shorts due to insulation breakdown under normal operating conditions.
The dealer service shop likely has an electrotester to test the coil's ability to produce a given spark under load.
For example, a Z1 coil should produce at least a 7 mm (.28 inch) spark.
Specs for the KZ550-B2 coils at hand are perhaps shown in the manual.
I don't see any obvious cracks in the coils. But if cracked, will invite moisture intrusion which shortens life of the coil and causes poor performance when damp.
Good Fortune! :)
  • zirafin
05 Apr 2016 23:57
#719487
thanks for answers my coils is not cracked ore any damages on it from outside, i understand its old ride . so i will try to by new coils and plugs and wires , thanks again
  • zirafin
06 Apr 2016 00:05
#719488
No eBay APP ID and/or Cert ID defined in Kunena configurationhi i found on ebay.com in germany :
my kz is kz550 b2 1981 and this coils is going for gpz550 a 1984 can it work ore be used ??
  • loudhvx
  • loudhvx's Avatar
06 Apr 2016 06:54
#719519
Yes it should work. You will need new wires. The original wires were probably 7mm. The new wires might be 8mm.
I recommend suppression wire with plain caps.
