Pickup/ Pulser coil Kz750E
- edhead74
02 Apr 2016 13:30
Trying to find replacement pickup coils for a 1981 Kz750E. Not having much luck finding any. Anyone know where i should be looking for some? Can i replace them with another year or even manufacturer? any help is greatly appreciated. Thanks
Es
- loudhvx
Re: Pickup/ Pulser coil Kz750E
02 Apr 2016 14:58 - 02 Apr 2016 14:59
You can use one from any year or size Kz as long as the pickup is the same type, that is, it should basically look exactly the same (or mirror image with different color wires). You can swap the left and right pickups as well (you'll just mount it upside down and have to extend the wires).
Yellow swaps with black.
Red swaps with blue.
The actual pickups can swap, or you can swap the pickup frame from one timing plate to another.
Pay attention to the screws. Some are brass and some are steel. Don't mix them up.
Also, don't mix up the magnets.
Here's some details on how to set them up in case you get things mixed up:
gpzweb.s3-website-us-east-1.amazonaws.co.../PickupAndRotor.html
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 02 Apr 2016 14:59 by loudhvx.
The following user(s) said Thank You: edhead74
- JR
02 Apr 2016 15:36 - 02 Apr 2016 15:36
Any kz 650 1981 - 83 or any 750/4 1980 to83 uses the same part
A quick ebay search (search kawasaki KZ pulse pulsing coil) shows there are a couple on ebay at the moment from 87 kz1000 police bikes.
The pickup coils look identical to mine but the backing plates are different. Should be easy to swap just the pickup coils or frame.
Alternative would be a Dyna electronic ignition from one of the dealers but I believe the original KZ system is a good one
Last edit: 02 Apr 2016 15:36 by JR.
