Ignition timing and process
  • zimmermanjoshua
  • zimmermanjoshua's Avatar Topic Author
31 Mar 2016 19:05
#718587
Currently i have a 1982 kz 550, that i have completely overhauled. i have one question/ favor. could some one explain to me as the service manual and dyna-s instructions are missing. when adjusting the dyna - s ignition on my timing adjuster i have a "f" on the Timing adjust do i use this timing for the 1/4 coils? and what mark what do i adjust to for the 2/3 coils. currently at the top there is a "t" ,'F", 1-4, ' ". on the other side there is a "t".
i understand the "t" is Top of the cylinder; 'F" is Fire but isn't there a F for 1/4 and 2/3 on the Timing adjuster?
Thank you in advance
zimmerman.joshua
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Ignition timing and process
31 Mar 2016 19:24
#718591
With the Dyna S you set the timing at the full advance mark then adjust down the idle. You can google them and get the instructions there.
www.mpsracing.com/instructions/Dynatek/DS3-3C.pdf
  • zimmermanjoshua
31 Mar 2016 19:33
#718593
Thanks Swest. is there supposed to be a full advance mark on both sides of the Advancer? or do you use the advance for both 1/4 and 2/3
thank you again
zimmerman.joshua
  • SWest
  • SWest's Avatar
  • 10 22 2014
31 Mar 2016 20:08 - 31 Mar 2016 20:09
#718604
There is but some bikes don't have one for 2/3' If that's the case you have to measure where 1/4 is and make your own marks for 2/3,
Last edit: 31 Mar 2016 20:09 by SWest.
  • zimmermanjoshua
01 Apr 2016 07:15
#718663
Hey man thank you, i'll test this tonight
thank you for your time
zimmerman.joshua
  • zimmermanjoshua
21 May 2016 11:39
#727761
Man the new timing is awesome had to take it off and mark the other side ;;; then whala ,.... all done awesome sauce...
zimmerman.joshua
