Who knows regulator wires?
  • car5car
  • car5car's Avatar Topic Author
  • Banned
  • Banned
16 Mar 2016 12:26
#715732
3 yellow wires go to stator
one is battery
one is ground.
What else?
I found old GoldWing regulator, maybe I'll install it on my KZ1000
Attachment IMG_1125.JPG not found
Attachment IMG_1122.JPG not found
Attachment IMG_1123.JPG not found
96 Yamaha Royal Star
82 Yamaha Virago 920
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Who knows regulator wires?
16 Mar 2016 12:58
#715738
New battery?
  • Nessism
  • Nessism's Avatar
  • Away
16 Mar 2016 13:02
#715741
Yellow to stator
Red is power output
Green is ground
Black is the sense wire - goes to a powered hot wire.
Read this, it may help... members.dslextreme.com/users/cbsaunders/...fiers_for_GS_use.pdf
The following user(s) said Thank You: car5car
  • martin_csr
  • martin_csr's Avatar
16 Mar 2016 19:57 - 16 Mar 2016 19:58
#715784
Just an fyi. From the diagrams your 1000E has the same voltage regulator as my 81 650-CSR, so you should be able to use one from a late model Ninja 500 or Vulcan 500 et al. (credit to loudhvx). I installed one from a low mileage 2007 EX500 ($25). The connector was reversed from stock, so I had to swap terminal pins. You can kinda figure out the year range of the r/r by the numbers on them, which get larger the newer they are.
Last edit: 16 Mar 2016 19:58 by martin_csr.
