1978 kz650 starter
  • drotti2004
  • drotti2004's Avatar Topic Author
1978 kz650 starter
12 Mar 2016 12:12
#715115
I changed my oil this week and installed new battery, now when I hit the starter button it makes a whiiny grinding sound and wont start till i keep pushing over and over again. I put walmart brand 10w40 in (supertech) in this time and was wondering if the oil could effect the starting.
Re: 1978 kz650 starter
12 Mar 2016 12:22
#715117
If you look at the label on the oil container I believe you will see the oil is NOT JASO-MA compliant. As a result, it may contain friction modifiers that should never be used in a motorcycle. You may want to try changing the oil and this time use the correct oil rather than oil intended to be used in automobile gasoline engines.
The sound when you operate the starter is very likely the starter clutch slipping. If so, the solution is to use the kickstarter or to replace the starter clutch parts. See ....
www.kzrider.com/forum/2-engine/593654-st...ch-kz750-1980#630265
  • drotti2004
12 Mar 2016 12:35
#715119
kickstarter not functional. I know you say oil is not good for bike but would that make the starter clutch slip more.
  • KZB2 650
  • KZB2 650's Avatar
12 Mar 2016 14:21
#715131
I'd try changing it to Valvoline bike oil or Rottella 10/40 or 15/40 and maybe pray ...... I changed mine to Mobil4T bike oil and the starter clutch started acting up on the first start after..... I think in my case it was just time but reg Valvoline bike oil fixed it for the rest of the summer but then came back in the fall when things really cooled off and the cranking of the motor was harder......... do a search here too tons of info on it and parts are not avaliable just anywhere anymore.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
