Im in the process of rebuilding my electrics on my z650-f2.
I´m using a M-unit V.2 for the rebuild so I´m thinking I need to keep the Ignition box, rectifier and starter solenoid from the original system, correct?
I have allready torn down the original setup, having the wiring chart handy I thought there would be no problem reconnecting everyting I needed. But I have one part that I don´t know what it is and I can´t identify it in the chart.
See attaced pictures. Markings on it says 1G13 and it´s connected in the original harness ritght next to the ignition box.
Any tips, directions in the right way are highly appreciated.
Regards,
Skaeggapa
Attachment 2016-03-09(1).jpg not found
Attachment 2016-03-09.jpg not found
