Dyna iggy..run hotter?
  • Wyliecoyote
  • Wyliecoyote's Avatar Topic Author
06 Mar 2016 16:41
#714187
Just wondering how much hotter an electronic iggy runs? Does it run hot enough that it would make it run lean enough that u would have to go up jet sizes? ...thx in advance
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: Dyna iggy..run hotter?
06 Mar 2016 16:46
#714189
Compared to what?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • SWest
  • SWest's Avatar
  • 10 22 2014
06 Mar 2016 17:01
#714191
I don't understand the question.
  • bountyhunter
  • bountyhunter's Avatar
06 Mar 2016 18:31
#714200
Maybe he is referring to the BS advertising claims that electronic ignitions "hotter spark" burns more fuel and so would make the engine run leaner. That's a myth.
  • Wyliecoyote
06 Mar 2016 18:34
#714203
Compared to points...
  • redhawk4
  • redhawk4's Avatar
06 Mar 2016 18:43 - 06 Mar 2016 18:45
#714204
bountyhunter wrote: Maybe he is referring to the BS advertising claims that electronic ignitions "hotter spark" burns more fuel and so would make the engine run leaner. That's a myth.
You may get a fuller fuel burn, with a bigger spark, but there would never be a difference that would require rejetting, The engine sucks in x amount of fuel with y amount of air through the carbs, all that's happening with a weak spark is not all the mixture is burned in a timely fashion. If you put bigger jets in you would just have an overly rich air fuel mixture, assuming the system was set up properly in the first place.
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
Last edit: 06 Mar 2016 18:45 by redhawk4.
06 Mar 2016 19:20
#714207
Maybe I'm wrong, but I would think if an engine has an air/fuel mixture under compression and a spark lights it off so it begins to burn the air/fuel will all burn or else be pushed through the exhaust system if not completely burned. I don't understand how a "hotter" spark is going to make more air/fuel mixture burn than a less hot spark. In other words, I would think that since the spark is only a momentary event, and that event ignites the air/fuel mixture which then burns to completion on its own, then any spark that ignites the mixture will burn the same amount of mixture since the spark is not a continuous event that lasts until the last bit of air/fuel mixture is burned. That's not to say that a hot spark is not desirable. To me the advantage of a hot spark is that it has a better chance of immediately igniting the air/fuel mix than would a weak spark. Since the air/fuel mixture will burn to completion whether ignited by a points or electronic ignition source I don't see how one would cause the engine to run hotter than the other. Ed
  • redhawk4
  • redhawk4's Avatar
06 Mar 2016 21:45
#714220
I' m not sure I exactly understand the benefits of a better spark or the use of twin plug heads on some machines, but it seems the faster all the fuel burns before the piston begins to move away from TDC the better for overall power output for a given amount of fuel. While we think of something lighting or exploding immediately, what we might think of as instantaneous in the normal sense, is not the same when pistons are moving at the speed they are inside an engine.
1977 KZ650B1
1980 Suzuki SP400
  • SWest
  • SWest's Avatar
  • 10 22 2014
07 Mar 2016 07:39
#714253
With a weak spark it is common for guys to go to the carbs first, lean them out only to find it doesn't run any better. A hot spark will aid in combustion given the locality of the plug in the cylinder. It was said the early Honda 750's had a fatter spark to compensate for the location of the plugs. In no case have I heard of a hotter spark causing the engine to run hotter unless it because it is finally running cleaner. That being the case you could say it does run leaner.
  • KZB2 650
  • KZB2 650's Avatar
07 Mar 2016 08:15
#714263
35,000 volts vs 15,000...... and since our bikes have a wasted spark system with less time to recover I will always run the Dyna's even though its may not be as big of a deal as it sounds.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • zed1015
  • zed1015's Avatar
07 Mar 2016 08:21
#714265
Wyliecoyote wrote: Just wondering how much hotter an electronic iggy runs? Does it run hot enough that it would make it run lean enough that u would have to go up jet sizes? ...thx in advance
Simple answer = NO.
  • Wyliecoyote
07 Mar 2016 08:45
#714277
K thanks...makes sense
