77 kz1000 eletrical/wiring questions
- jowek70
26 Feb 2016 07:50
Hello forum,
My dad and brothers and I are working on a project 77 kz1000 LTD that he picked up for cheap and has been sitting in the garage for the last 2 years or so. We are doing a few chassis, engine and cosmetic upgrades. One of the things we'd also like to change is the electrical and wiring. We would like to upgrade the left and right control switches, fuse block, starter solenoid and accompanying components.
Is there any issue in doing this?
We plan on doing this properly with the correct wire terminals/crimps to accommodate the upgrades so it will connect to the stock wiring harness.
Looking for any and all help/information.
- StreetfighterKz
Re: 77 kz1000 eletrical/wiring questions
26 Feb 2016 10:17
I'm in the process of doing pretty much the same thing to my Gpz project...newer controls, Mosfet R/R from a Zx10, newer blade style fuse box, modern Suzuki starter solenoid, etc. I want everything to look and act as factory and have ended up pretty much disassembling the factory wiring harness and making my own. I'm not saying not to attempt it but I personally found it to be a deep, deep rabbit hole.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- jowek70
26 Feb 2016 12:21StreetfighterKz wrote: I'm in the process of doing pretty much the same thing to my Gpz project...newer controls, Mosfet R/R from a Zx10, newer blade style fuse box, modern Suzuki starter solenoid, etc. I want everything to look and act as factory and have ended up pretty much disassembling the factory wiring harness and making my own. I'm not saying not to attempt it but I personally found it to be a deep, deep rabbit hole.
Later, Doug
Looks like its coming along nicely.
We are getting a good condition stock harness and modifying it for our application, so similar to you here. Thanks for the info though and its good to see somebody else in the same boat. I don't like being the pioneer, ha.
Anyways, I forgot about the R/R so what year zx10 did you get yours from? is there any that will not work? there is a budget to this from what my dad keeps telling us, haha.
- spdygon
26 Feb 2016 20:12
Z1E has all new harness for about $160 ship.
I have purchased two sets from them .
One for my 76 kz900 and 77kz1000.
As for the hand controls...you can't find Repo for your model especially if your hazard control is on the left control.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
1974 Z1 900 project
- jowek70
07 Mar 2016 08:09
Thanks for the information.
Good to know about the harnesses as we need a stock one to modify as the current one seems to have been in some type of electrical fire and is pretty mutilated by the previous owner(s).
- jowek70
09 Mar 2016 13:13
Ok. Did some shopping around on z1enterprise website and it was great to see all the stuff available there.
i'll update as we move along with this.
- jowek70
16 May 2016 08:40
Update:
Scored a very good deal on a good, used OEM harness on ebay.
Getting the electrical underway since the engine is going out soon and the frame/etc just came back from powder coat.
Going to source a new starter motor, update to modern starter relay, update to reg/rect. unit, update thumb switches, remove all unnecessary things from the electrical system, update fuse block, LED turn signals and proper relay, integrated rear light, modern horn.
Hoping to have all this finished up by June.
Using varying connectors from cycleterminal.com (they have been great for me in the past with projects like this)
- jowek70
14 Jun 2016 14:16
So much for June ha
Just got new handlebar switches
Starting into this tonight mapping out the various parts and matching to stock harness
