82 kz550 starting problems
- greene.1993
20 Feb 2016 14:26 - 20 Feb 2016 14:28
Hey guys I have an 82 kz550 ltd and I did my own wiring cuz the old wiring I wasn't getting any power to the lights or the starter, I did a bare bone wiring on it and now the lights work but when I push the start button I'll hear a click and the lights well turn off, checked the fuses and they were good, reconnect the battery and the lights well turn on but when I push the start button it well do it all again any help? This is the diagram I used
Last edit: 20 Feb 2016 14:28 by greene.1993.
Re: 82 kz550 starting problems
20 Feb 2016 15:45
Sounds like the battery is dead.
- greene.1993
20 Feb 2016 16:02greene.1993 wrote: It's a new battery with 12.30 volts
Should be something near 13 volts if it's fully charged.
- greene.1993
20 Feb 2016 16:06
Then why well the lights turn off as soon as u push the start button.
20 Feb 2016 16:33
Batteries can test good but no amps behind it.
- loudhvx
22 Feb 2016 06:49
I agree on the battery being the most likely suspect.
Did you try to jump the solenoid to get the motor to crank?
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- JENKFITLIFE02
- No Regrets
22 Feb 2016 07:12
Make sure the terminals are nice and tight, that happened to me this weekend
