82 Kz750 ignition coils wired backwards
  • dom2570
  • dom2570's Avatar Topic Author
09 Feb 2016 11:00
#710150
I recently did a top end rebuild on my 750. Once I got it all back together, I had some issues getting it to start. When I did get it running it was rough,I had some backfire and really rough idle. I blamed it on leaky carb boots. I replaced the boots today while doing that, I noticed that I had stupidly installed the ignition coils backwards.
By backwards I mean the positive was on negative and negative on positive. I had/have the spark plug wires ran correctly( right to 1-4 left to 2-3). I have not had a chance to get a battery in the bike and try it out but I was curious if having that wiring screwed up could have caused the issues? Also what are the chances it could have ruined that coils? I ask because I don't have a multi-meter yet, one is on the list of tools to get once I get paid.
Whip it like a mule!
  • Nessism
  • Nessism's Avatar
Re: 82 Kz750 ignition coils wired backwards
09 Feb 2016 11:35
#710155
I'm not positive but don't think coils have polarity.
BTW, the coil wires and spark plug caps unscrew on that model. You might want to consider updating those parts.
09 Feb 2016 11:39
#710156
Are you saying you ran the engine with no battery in the bike? :huh: Ed
  • dom2570
09 Feb 2016 12:18
#710163
They are marked with polarity. That is how I figured out they were backwards. I have new ngk plugs and wires.
I haven't gotten a new battery yet because it is winter. I have one good battery in my 440 that I am currently using as my main bike. I just swap it around. When spring comes and it warms up I'll get a fresh battery.
09 Feb 2016 12:37
#710168
Ah, good. I was afraid you might be running it while hooked up to a charger or other power source that might fry things. Ed
  • dom2570
Re: Re:82 Kz750 ignition coils wired backwards
09 Feb 2016 12:49
#710172
Turns out that was the problem. Got her to fire right up. Made it down the street a few times before we ran out of gas.
