handle bar switches and twist throttle
  • goldylox
  • goldylox's Avatar Topic Author
06 Feb 2016 17:30
#709766
Wat after maket units are ppl using on the switches and twist throttle set
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: handle bar switches and twist throttle
06 Feb 2016 17:45 - 06 Feb 2016 17:48
#709768
I'm using an aftermarket switch assembly (can't remember manufacturer but looks like an OEM switch housing from a newer sportbike) on the left side and a Motion Pro throttle assembly with a Zx12R switch assembly on the right of my '78 1000. My '83 Gpz has EX650 left switches and Zx9 right switches with a Cbr1000RR throttle assembly.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
Last edit: 06 Feb 2016 17:48 by StreetfighterKz.
  • NakedFun
  • NakedFun's Avatar
06 Feb 2016 18:08
#709769
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
  • CoreyClough
  • CoreyClough's Avatar
  • GPz550 Addiction
07 Feb 2016 03:09
#709793
If you current set up uses a push and a pull cable, then Motion Pro can custom make you a Custom Rev2 Throttle Kit. They also have a Universal On/Off, Stop/Start Switch you would need to hard-wire to your existing harness. I have one made for my 1985 GPz550 using CV30 /CV32 Carbs. Works great! If you have a single cable pull system, there could be something else they can make for your application.
www.motionpro.com/featured/rev2_throttle
E-Mail them for more information. Here are some pictures of that throttle on my GPz550.
'85 GPz550(ZX550-A2)
The following user(s) said Thank You: goldylox
  • ed spangler
  • ed spangler's Avatar
  • Tennessee Z
07 Feb 2016 11:24
#709851
NakedFun wrote: Lots of options here.... www.dimecitycycles.com/motorcycle-parts.html?cat=1865
Cory
^+1
What Cory says!
Have 1975 Kawasaki Z1-B & 2003 Harley Davidson Heritage Softail Classic
Had Hondas, Harleys and many ,many Z Series Kaws both Std. & LTD's
