1100A ignition
- blue22
1100A ignition
31 Jan 2016 01:34
Im wondering,what ive done wrong in the past!!
SO now ive cleaned the carbs 3 times on this bike.
But initially,i had her running,although rough, i checked the coils-GOOD,an the Pulsing coils-GOOD.
Then i tried to run her after the 2nd carb clean, and she was missing, another check,one of the coil HT checks was bad,So new dyna coils,all good.But still running a bit off so clean them again, and give her a run, AH much better, but still fluffing on 4,let her cool down cos its getting close to great,and i see the pipes on 1 and 4 arent looking too hot,right so check those pulsing coils,1and4 dead WTH,let it cool down take them off and i get varying resistances,then back to 0.
Ok so search and it seems i have to buy a complete setup,
Does anyone know of a supplier so i can simply solder on new coils ,that'd be great
- daveo
Re: 1100A ignition
31 Jan 2016 06:25
How are the spark plug wires and caps? If old, you may want to get a new set.
Every little thing helps, in my experience.
1982 KZ1100-A2/1170 sleeper 😀
- loudhvx
Re: 1100A ignition
31 Jan 2016 18:32
Does it have mechanical advance?
If so, you can use any pickups from any other mechanical-advance, inline-four, KZ.
The pickups themselves can be swapped, even though the timing plates may be different sizes for the different size bikes. You can also swap the 1-4 pickups with 2-3 pickups. You just have to get the wire colors correct.
Black swaps with yellow.
Blue swaps with red.
Here's more detail on how to get the magnets and screws in the right place.
gpzweb.s3-website-us-east-1.amazonaws.co.../PickupAndRotor.html
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- blue22
Re: 1100A ignition
01 Feb 2016 00:07
Yep cheers Daveo, nu leads and plugs with the new coils
- blue22
Re: 1100A ignition
01 Feb 2016 00:10
Thanx, loudvx yep has mechanical advance, the only USED pulser coils i could find were from the US, over $100USD posted to me, i thought perhaps there was a way to get new coils fitted to the old plate and wires,sems not, and theres plenty of info on that link eh
- blue22
Re: 1100A ignition
04 Feb 2016 13:55
Thanx guys, funnily enough i dont have any pix of the bike together, , i have plenty of pix particular parts for re-assembly,here is how she currently sits,waiting for some new pulser coils.
Oh and i see theres some of you in Tassie shortly, im over with the vic Ducati club on the 12th,guess we wont see each other.
And the weather here is South Eastern Victoria,usually best this time of year,around 18 to 30 c,most excellent for doing what WE love best!!
Attachment DSCN0220.jpg not found
Re: 1100A ignition
04 Feb 2016 14:55
Have you checked the valves?
- blue22
Re: 1100A ignition
04 Feb 2016 16:17
Steve, did a compression test, checked and adjusted the valves, i had a sneaking suspicion the cam chain was near its end, but couldnt quite tell.
Anyhow, about half of the cam retainer bolts stripped when i undid them,i just replaced them the same as the one that had already stripped,(someone had simply put in an imperial bolt,no re-tap or anything).
I decided i really needed to make sure she was right, so i pulled the head,tapped and heli coiled her,fitted a NEW cam chain, and was now happy the cam chain guides were fine,i decided the valves could do with a touch up but the inlets were too thin,so new set of them,and to add to the fun, redo those bloody clearances.
Did i tell you about the tank,some numb nuts had put in self tappers to hold on the emblem on one side,GUESS WHAT.
Oh and the rusty seat base that had been bogged up and painted.
Cant wait to ride her!!
Re: 1100A ignition
04 Feb 2016 16:35
Yeah, PO's suck.
