which accel super coil kit for my 1981 kz440?
- Benny77
28 Jan 2016 08:02 - 28 Jan 2016 08:02
Last edit: 28 Jan 2016 08:02 by Benny77.
- cafebrat
Re: which accel super coil kit for my 1981 kz440?
30 Jan 2016 17:44
If you have a points ignition it should be 3,3 - 4,8 ohms. For the electronic ignition 1,5 - 2,8.
I believe the 81 has electronic ignition and you can buy any 3ohm coil. Dynateck or accel
83 Kawasaki Kz1100 LTD
81 Honda cm400
72 Suzuki T500 Titan** 2-stroke
81 Honda cm400
The following user(s) said Thank You: Benny77
- Benny77
31 Jan 2016 08:50
Thank you so much for your reply!!! I do have the electronic ignition, I just wanted a second opinion before ordering the parts!!!
- cafebrat
31 Jan 2016 09:12
No problem. I just bought a set of dynatek mini 3ohm coils for my kz1100 this week. Youll probably want to replace the wires too, i know mine were hardened into their position and wouldnt re-route to fit the new coil position. You want solid copper core wires, 7mm or 8mm. Part# Dw-200 for dynatek
81 Honda cm400
81 Honda cm400
