Replacement plug wires for 1984 kz440 Ltd
- BornAgainBiker
01 Jan 2016 04:47
Hi All,
I'm looking to replace the plug wires on my 1984 KZ440 ltd with electronic ignition--it looks like it still has the original plug wires. I don't want to spend big bucks on replacement wires, just want a set that will do the job. Any recommendations?
All the best, Jeff
1984 KZ440 D6
1984 KZ440 D6
Re: Replacement plug wires for 1984 kz440 Ltd
01 Jan 2016 05:25
Ordinary 7mm copper core wire from any reputable auto parts store. New caps would also be a good idea. If you are using resistor spark plugs, then there is no need for resistor wires or caps.
The following user(s) said Thank You: BornAgainBiker
- dom2570
Re: Re:Replacement plug wires for 1984 kz440 Ltd
01 Jan 2016 08:21 - 01 Jan 2016 08:23
No eBay APP ID and/or Cert ID defined in Kunena configurationThese are what I use on my 440s.
Whip it like a mule!
Last edit: 01 Jan 2016 08:23 by dom2570.
- ThatGPzGuy
01 Jan 2016 09:30
Any 7MM copper core wire will work. I use the sets that Z1 sells on my fours. For the twin café bike I bought some vintage looking wire on eBay for $2.50 a foot.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- rrsmsw9999
01 Jan 2016 11:32 - 01 Jan 2016 11:34
Just did this. Dennis Kirk has the caps for bike for less than 2$ a piece. 7MM wire was less than 10 buck for 10ft. Used the same twist caps and grommets at the coils. One of the caps was shorted, no conductivity. Discerning ears on KZR could hear I was on 3 cylinders. I also worked off the sleeves to reuse. This was a pain in the ass, but I could not find the sleeves new at the auto part store or online. It really helps to put them back on right. :ohmy:
R
R
Attachment IMG_1463-2.jpg not found
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Last edit: 01 Jan 2016 11:34 by rrsmsw9999.
