82 kz550 c starting problem
  • greene.1993
  • greene.1993's Avatar Topic Author
20 Dec 2015 17:50
#703804
82 kz550 c I have a problem with it not cranking at all. The battery reads 10.66 volts, I turn the key to the on position, turn the kill switch in run, pull in the clutch, and when I go to push the start button I get nothing, and also the lights won't come on. I checked the main fuse for continuity, as well as the killswitch, start button, key switch. Plz help I just turned it into a bobber
  • nickleo373
  • nickleo373's Avatar
Re: 82 kz550 c starting problem
20 Dec 2015 18:13
#703805
10.6 volts is way too low to start the bike. It needs to be about 12.5 minimum
1981 KZ550C LTD
"If you ain't first, you're last"
  • greene.1993
20 Dec 2015 18:20
#703806
Do you think that's the reason the lights won't turn on either?
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Timbox
  • Timbox's Avatar
Re: Could be a bad connection
21 Dec 2015 13:42
#703902
If there are no lights and or "clicking" it could be a bad connection with the battery and the cables. Lose wire or bad connection at the solenoid?
Long time shade tree wrencher
GPZ550 project
03 B1250s
2002 Gold Wing
2006 VTX 1800
1982 XJ1100 x 2
1997 HD Sportster
