plug caps
- Steven Wilson
plug caps
03 Dec 2015 16:10
Do I need to run resistor plug caps, Im using standard copper core leads?
Re: plug caps
03 Dec 2015 16:20
No.
Re: plug caps
03 Dec 2015 18:18
Unless you don't want static some cager's AM radio. :lol:
Re: plug caps
03 Dec 2015 18:30
Kawasaki speced resistor caps and copper wires. You don't "need" them per say, but it's generally advises to either run resistor wire and non resistor caps, or visa versa.
- bountyhunter
Re: plug caps
03 Dec 2015 22:49
If you have electronic ignition with hall effect sensors, the EMI might cause erratic firing. It won't hurt to run resistor caps with copper (non resistor) wire, just don't run res caps and resistor wire together.
Re: plug caps
03 Dec 2015 23:58
Or resistor plugs with resistor caps or wires. One resistor out of the three is enough.
- daveo
Re: plug caps
04 Dec 2015 03:11Steven Wilson wrote: Do I need to run resistor plug caps, Im using standard copper core leads?
Not if your spark plugs are resistor (R) type. If they are not, then probably yes. :blink:
1982 KZ1100-A2/1170 sleeper 😀
