Best H4 Halogen bulb?
- daveo
15 Nov 2015 07:37 - 15 Nov 2015 07:38
What is currently the best available Halogen replacement bulb for a stock/standard 55/60 watt, three prong setup?
I want a bulb that directs the light properly when switched from low to high beam! With all I have used the beams end up too low then way-too high when switched. :S
Then, there is the brightness consideration...for riding those long dark and lonely roads at night, when the brightest low-beam and longest high-beam are needed...
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 15 Nov 2015 07:38 by daveo.
- pete greek1
Re: Best H4 Halogen bulb?
15 Nov 2015 07:47 - 15 Nov 2015 08:06
No eBay APP ID and/or Cert ID defined in Kunena configurationThere was a right up about a month & 3 weeks ago about how great these bulbs are & they're plug & play
Pete
Pete
Last edit: 15 Nov 2015 08:06 by pete greek1.
- pete greek1
15 Nov 2015 08:11
- daveo
15 Nov 2015 11:13
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configuration
More like this type:
pete greek1 wrote: There was a right up about a month & 3 weeks ago about how great these bulbs are & they're plug & play
Pete
- pete greek1
15 Nov 2015 11:21
Those are for cars, & may not be plug & play
Pete
daveo wrote:pete greek1 wrote: There was a right up about a month & 3 weeks ago about how great these bulbs are & they're plug & play
Pete
Pete
- daveo
15 Nov 2015 11:48
I read this. and request input before I buy another bulb...
ridershandbook.com/the-best-motorcycle-bulbs-put-test.html
pete greek1 wrote:daveo wrote:pete greek1 wrote: There was a right up about a month & 3 weeks ago about how great these bulbs are & they're plug & play
Pete
Pete
- pete greek1
16 Nov 2015 08:41
The problem with that article on the testing is almost 6 yrs. old, & the opt7 H4 bulbs weren't invented back then
I'm going to post on that 2 month old thread, & see how that opt7 bulb is working out for the guy who started the thread
Pete
daveo wrote:pete greek1 wrote:daveo wrote:pete greek1 wrote: There was a right up about a month & 3 weeks ago about how great these bulbs are & they're plug & play
Pete
Pete
Pete
