Electrical failure
- Unz
Electrical failure
11 Nov 2015 11:07
Hi
I've been testing the electronics on my z750e1 1980
Its been tampered with during a convertion to a trike, I have no spark,
I've been testing the kit with a multimeter , I've replaced the coils and ic igniter so far, no luck,
Is it possible the electronics have been fried whilst previous owner welded the frame for the new Axel, and not taking the earth off the battery?
- MFolks
Re: Electrical failure
11 Nov 2015 13:33
Assuming you battery's good, check the Negative(-) cable from the battery post to the frame. Any corrosion can lower the current/voltage, so the bikes ignition won't work. It must be clan and tight, for maximum current flow.
The pick up(or as Kawasaki calls the "Pulsing coils", will need an ohm check to see if they are working. here's how to test them:
Ohm Checking Pickup(Pulsing) Coils
The pickup coils on the Kawasaki’s with the factory supplied electronic ignition can sometimes fail or become intermittent due to heat and vibration.
1.Trace back from where the pick up coils are mounted,(under a right side CD sized cover) locate and disconnect a small 4 pin connector. Using a multi-meter set on OHMS and range of X 100 check between the BLUE and BLACK wires(#1 and #4 sparkplug wires) for between 360- 540 OHMS.
2.For #2 and #3 sparkplugs the wire colors will be YELLOW and RED, again 360-540 OHMS.
3.If the pickup coils are suspect of failing due to heat, they can be stressed using a hair dryer without the need of the engine running.
4.A replacement set of pickup coils might be obtained from a dealer who serviced the police Kawasaki’s.
5. If replacement pickup coils are not available, your next choice would be to order a Dyna “S” electronic ignition system from www.z1enterprises.com It replaces the IC igniter with a smaller module located where the mechanical ignition advancer was mounted.
6.Checking with Kawasaki.com website has determined that the Pick up(pulsing) coils are available . The pulsing coil # is 59026-1133 and replaces the older # 1002, 1012 which were used from the MKII motors until the 2005 P24.
Testing Kawasaki Ignition Coils For Input Voltage
When voltage testing Kawasaki Ignition Coils, the following needs to be done:
1. Remove the fuel/gas tank to access the coils.
2. Fully charge the battery.
3. Using a multimeter, set it up for VDC(Volts, Direct Current), range of 20.
4. Turn on the ignition switch and the run/stop switch to “Run”.
5. Put the multimeter’s RED probe on where the red or red/yellow wire goes on the ignition coil.
6. Put the multimeter’s BLACK probe on either the battery Negative(-) post/terminal or a good frame ground.
7. You should be able to see battery voltage at the ignition coil connection, but this depends on the current draw of other items in the same circuit.
8. If the tested voltage is down to 8-9 volts, you probably need to clean the many and various electrical connectors.
9. To check the spark output at the sparkplugs, use these:
Ignition Spark Testers
www.lislecorp.com/divisions/products/?pr...ivision=1&category=8
www.lislecorp.com/divisions/products/?pr...ivision=1&category=8 Instead of grounding the sparkplug with the sparkplug wire attached, looking for a spark. This method puts the IC Igniter and ignition coils at risk of failure due to high currents, and possible internal shorting.
The following user(s) said Thank You: GPz550D1, Unz
- MFolks
11 Nov 2015 13:35
Cleaning Motorcycle Electrics
Get some of the De-Oxit electrical contact cleaner and figure on spending a good day going from the front of the bike to the back. It’s a plastic safe cleaner/preservative. www.deoxit.com is their website.
On the older Kawasaki's, a majority of electrical connectors are inside the headlight housing requiring removal of the headlight, then the fun begins.
Do one set of electrical connectors at a time to avoid mixing up what connects to where. Usually disconnecting, spraying with De-Oxit and reconnecting is about all you'll need.
However, when encountering the green crud of corrosion, a brass wire brush may be needed on the pins you can reach.
Some 400-600 grit wet and dry sandpaper strips rolled into a tube should reach the male and female pins in the more difficult to clean connectors.
Smoker’s pipe cleaners, cotton swabs and wooden toothpicks work as cleaning aids.
Really small electrical connectors may require the use of a welders tip cleaning tool assortment.
Most pins in the connectors are coated with a thin plating of tin, and others may be nothing more than copper or brass.
If moisture is added, the resulting corrosion lowers the voltage/current being carried causing dim lights, slow engine cranking, slow turn signal response and lower input voltage to the ignition coils resulting in weak spark.
The left and right handlebar switch pods will need attention too as they have circuit functions like turn, horn, run/stop, and start.
Usually a spritz or two with actuation of the switch is about all needed for these switches unless corrosion is detected and then careful disassembly is required.
The ignition switch may or may be not sealed to allow spraying the internal contacts. I urge caution if attempting to open this up as springs, and ball bearings may fly out never to be seen again!
If your bike has the older style glass tubed fuses, I suggest replacing them as vibration can cause internal failure. AGX is the type used, and most auto parts stores can get them for you.
Clean the fuse holder clips, looking for signs of overheating(discolored insulation, signs of melting).
I use metal polish on a cotton swab, followed by spraying another clean swab with the De-Oxit and then rubbing the inside of the fuse clip.
All battery cables must be clean and tight for maximum current transfer. Check the cables going from the Negative(-) battery terminal/post to the engine mounting bolt
Also the one going from the Positive(+) terminal to the starter solenoid and from there to the starter motor.
If any battery cable feels ”Crunchy” when flexed, replace it as possible corrosion is inside the insulation.
Each "Bullet Connector" will have to be sprayed to ensure good connectivity, especially the ones going to the energizing coil of the starter solenoid.
The alternator output “Bullet Connectors” are usually behind the engine sprocket cover and will need inspecting and cleaning too.
The turn signal light sockets will benefit from a spritz from the contact cleaner along with the tail light/brake light socket.
Some brake light switches can be sprayed on the actuating rod, with the spray running down inside to the electrical contacts, others may be sealed requiring replacement if the switch is intermittent in operation.
Some people put the Di-Electric Grease on cleaned terminations/connectors, I don’t, as I’ve read/heard it can cause problems when it gets hot, actually insulating the connections, so the choice is yours to use or not.
“I spent a weekend going through every electrical connection and switch on the bike with a little scotchbrite pad and DeOxit - what a difference! Everything was brighter, gauge backlights, indicator lights, turn signals, I was getting a nicer spark, it fired up quicker, etc. Well worth my time. WELL worth it! “
From a forum member at www.kzrider.com
Re: Cleaning the many and various Motorcycle electrics.
I used the De-oxit D-5 spray on all the electrical connections of my 78 Kz1000 that had sat for twenty years .
When I parked the bike in 92 I was starting to have troubles with some of the electrical system, but after pulling everything apart and giving it a spray , reconnecting the connectors and working them back and forth a few times, then gave them another shot of spray to wash them off before the final reconnection.
Everything still works perfectly and has for over 7000 miles this year.
I am extremely happy with the results , a lot of the connectors were green when I started and after the cleaning they looked new ( shiny gold )
I found the Deoxit D-series, D-5 spray in a 4 oz can at a big electronics store called Frys in Illinois, don't get the small cans at Radio Shack , they are different and meant for computer type stuff.
store.caig.com/s.nl/sc.2/category.188/.f
Recommendations:
Excellent contact cleaner from audio to ac power contacts
I've been an A/V Tech-Roadie for over 30 years and have used Deoxit since it was first introduced. I've cleaned /rejuvenated volume controls,switches and audio connections on everything from guitar amps to full blown recording consoles. It not only cleans mild to excessive corrosion but the lubricant keeps the part in good working order months afterwards. Much easier than replacing a hard to replace part. I also spray it on all the audio connectors periodically to insure good connectivity. Along with my A.C. power plugs and quad boxes that are used outside for live shows to prevent corrosion from the elements.
Good stuff. Obviously highly recommended.
Great Stuff
I used this stuff on my 35 year old Kenwood KA-7300 amp which had not been used in more than 10 years and it was fantastic. When I first tried to use the amp, all of the switches only worked sometimes and the static and intermittent sound was unbearable. I thought that my left channel was not working because it had such a low output compared to the right channel no matter where the balance was set. After cleaning all the input/ and output jacks and the switches along with vacuuming out the inside of the amp, the amp works great and sounds like it did back in the day! I was more than pleasantly surprised!!
I've used DeoxIT for years. My first use was on a BMW instrument cluster that an $800 "reno" hadn't fixed. I sprayed the several connectors and mates, dozens and dozens of connectors, let it sit overnight and reinstalled it in the car. That cured every problem. Years after manufacture one or more of those connections could get iffy, and they do. Since then I've fixed several instrument clusters, engine and transmission computer problems caused by the same thing, connections, and no telling how many other electrical connection problems in cars.
An Effective cleaner-rejuvinator!
I used this to clean the pots, switches, and faders on my old Allen & Heath SR416 mixer. Everything is working top-notch again and everything moves/slides with ease. DeoxIT is a great product and it always improves sound quality and equipment life. This is the only cleaner you need!
Trust MFolks , the guy's a true rocket scientist and really knows what he's talking about.
JD
Recommendations:
Great Stuff
JD
- MFolks
11 Nov 2015 13:38
The left and right handlebar "Switch Pods", have been know to be suffering failed or failing factory soldering jobs, especially on the older bikes. Open up the left and right "Pods", looking for grey soldered joints. If any are found, I've got a repair procedure, just ask....
- Unz
18 Nov 2015 08:01
Hi thanks so much for all your comments and help, I've been over the bike with a multi meter, replaced the coils, and repaired a joint in the cables from the pulse coils (removed joiners, soldered cable.,think bike was crash repaired at some stage)
And now have spark, the engine is firing but won't burst into life,
I'm wondering now if I have the plugs on the spark plugs, thought I put them back as I found them, I know I think it fires 1243,... 1 being left side when sat on it, but dunno how it works the other end at the coils ie which is 1234 the coil end.
Hopefully someone will decipher what I'm trying to say
- pete greek1
18 Nov 2015 08:57
The wires from one coil are for cylinders 1 & 4 & the other coil 2 & 3, as you're siting on the bike
Pete
Pete
The following user(s) said Thank You: Unz
- MFolks
18 Nov 2015 12:38
Ignition Coil Primary And Secondary Wiring
Ignition coils on the 80’s Kz1000,Kz1100’s and Gpz1100’s are wired the same, that is as you sit on the bike, the LEFT ignition coil primary(small wires) are two wires, RED and BLACK. The secondary (or sparkplug wires) go to #1 and #4 sparkplugs(your primary wiring may be different).
Read carefully, as the 550’s, 650’s, 700’s & 750’s are backwards to what is listed for the bigger 4’s.
The cylinders are numbered left to right as you sit on the seat; #1,#2,#3, and #4.
For the RIGHT ignition coil, the primary wires, again are two wires, RED and GREEN, with the secondary going to #2 and #3.
The RED wire gets it’s voltage from the run/stop switch on the right handlebar switch pod. Your primary wiring may have a different color.
The BLACK and GREEN wires connect to the IC Igniter(if the bike has the Kawasaki supplied electronic ignition) it actually gives the coils their grounds to fire the sparkplugs. The RED wire is common to both ignition coils.
Primary(small wires) side of the coils will read between 1.8 to 3.0 ohms.
Secondary(sparkplug wire ports)side of the coil will read between 10.4K to 15.6K ohms. These ports are wired together, so it makes no difference which is used, as long as the correct coil to sparkplug configuration is followed.
The sparkplug caps should read 5K OHMS(5000), any higher, or a reading of infinity means new caps should be ordered. When re-installing the old or new sparkplug caps, cut about ¼” off the sparkplug wires for a new un-corroded connection.
Never run surpression sparkplug wires with sparkplug caps containing the 5000 ohm resistor, as now there will be two (2) resistances in the ignition coil’s secondary circuit, causing weak and intermittent spark.
To stress the ignition coils, take a hair dryer, heat the coils and see if the ohm readings change from cold to hot . If they do, it’s time to buy new coils.
Keep in mind, the wiring is reversed for the 550’s, 650‘s,700’s, and 750‘s, that is the RIGHT coil primary will be two wires, RED and BLACK with the secondary(sparkplugs) going to #1 and #4.
The LEFT coils primary wiring would be again two wires, RED and GREEN, with the secondary(sparkplugs) going to #2 and #3.
An indication of black and sooty sparkplugs may not mean a carb or carbs are in need of cleaning, but may mean the input voltage is low.
When checking the input voltage to the ignition coils, first have a fully charged battery, and the using a multimeter, set it up to measure VDC(Volts, Direct Current), range of 20.
Put the RED probe from the multimeter on the same terminal that either a RED wire or ones that’s RED with YELLOW stripe, and the BLACK probe on either a good frame/Earth ground or the battery Negative(-) terminal/post.
Depending on the motorcycles current draw( lighting, and other high amp needs) the reading might be 10 volts or more, but if the reading is down around 8 volts or less, this indicates a corrosion or wiring problem needs correcting to improve input voltage to the coils.
These engines have what is known as a “Wasted Spark” that is, a sparkplug will fire during an exhaust stroke. It does no damage and many other motorcycle engines have this design.
