How to use points plate pry points on kz650
- aenikolopov
06 Nov 2015 09:12
Hi, I'm trying to adjust the ignition timing on my 1980 kz650 F1. I have set the points gap, and am now moving the plate the points are mounted to. I understand that KZ650s, before moving to electronic ignition, had 2 types of points plates setups, illustrated below:
Mine is of the sort pictured in (A). I am trying to move the plate, and I think I am supposed to be able to use the set of 4 notches at approximately 1 o'clock on the plate to move the plate around. However, I see nothing to pry against. How am I supposed to be using this?
- moneypit
Re: How to use points plate pry points on kz650
06 Nov 2015 10:31
If it were me, I would loosen the screws alittle and put a screwdriver in the slots and give it a slight tap.
2-76 kz900
St Paul MN
St Paul MN
- rstnick
06 Nov 2015 12:48
Yes, just loosen the 3 screws holding the plate, and then it can be rotated.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
- aenikolopov
09 Nov 2015 06:41
Right, I can do that, it just seemed to me that having several of them implied some sort of ability to pry, rather than just insert and tap. Anyway, thanks for the advice!
