Motogadget M-Unit
- Dave44
Re: Motogadget M-Unit
11 Dec 2019 12:10
Hi, I'm new here. I am re-wiring my bike for the first time and installed an M-Unit. All the wiring has been very straight forward and I know nothing about electrics. I can get everything to work except the ignition. Revival Cycles has an article saying that if you have a CDI it will not work with an M-Unit unless you place in a relay. Is the IC Igniter a CDI? Has anyone else had any issues wiring the ignition to an M-Unit?
- loudhvx
12 Dec 2019 07:21 - 12 Dec 2019 07:22
If the bike is an inline-four Kz, then the IC igniter is NOT CDI. It is transistorized flyback, AKA transistorized Kettering, sometimes it's called inductive, but that is a bit ambiguous. (CDI does not use a transistor as it's main device, it uses a thyristor.)
CDI is a very specific type of electronic ignition and can be identified by how it's wired. It is often wired very differently from transistorized Kettering, which is probably why it matters on the M-unit.
All that said, you will find many sources online that refer to all Kz ignitions as CDI. Those sources are just simply equating CDI to mean any electronic ignition, and that would be wrong, as anyone trying to wire it would find out.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 12 Dec 2019 07:22 by loudhvx.
- Dave44
12 Dec 2019 15:04
aah, ok that is interesting. Thanks for that. I have a 1982 Gpz750.
