KZ440 runs on one cylinder
  • nickleo373
  • nickleo373's Avatar Topic Author
29 Oct 2015 14:45
#696455
Hey everyone
A friend of mine purchased a KZ440 a few days ago that the PO insisted was a good running bike. We finally got it running after a carb clean, but the right cylinder isn't getting any spark. We installed a new battery and new spark plugs. We swapped the spark plug wires between the two coils and the wire plugged into the left coil would always have a good spark, and the wire to the right coil had no spark. Does this sound like the right coil is bad?
1981 KZ550C LTD
"If you ain't first, you're last"
  • punisher11b
  • punisher11b's Avatar
Re: KZ440 runs on one cylinder
29 Oct 2015 14:51 - 29 Oct 2015 14:51
#696456
If you switched the leads but the same side is the problem then I would suspect the coil. You should be able to test the coil with an ohm meter to tell if it's in spec.
- good luck
Last edit: 29 Oct 2015 14:51 by punisher11b.
  • JR
  • JR's Avatar
29 Oct 2015 16:31
#696466
You could also check the plug cap and plug lead. Take the plug cap off the plug lead. Cut the plug lead back about a quarter inch and screw the cap back on the lead.
