Very weird ignition switch problem.
  • New 750
  • New 750's Avatar Topic Author
24 Oct 2015 08:10
#695738
So my bike will start without a key in the ignition and turned too off! I have no lights is all, then if I put the key in and turn it to run my dash and headlight, tail light all pop on? Wtf I cannot shut the bike off with the key, I did the coil mod and must remove the fuse to shut the bike off! All the wires behind the aftermarket ignition switch are hooked up, this just started today, what could be the cause?
As always thanks.
1977 kawasaki KZ750
  • missionkz
  • missionkz's Avatar
Re: Very weird ignition switch problem.
24 Oct 2015 08:26
#695741
Your wiring is wrong and the coils must be hot all the time.
Does the battery go dead after a few hours?
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • jackleberry
  • jackleberry's Avatar
24 Oct 2015 08:30
#695743
You say you did the coil mod... It sounds like the relay you used has failed in the closed position or a couple of the wires have shorted together. Try a new relay.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
  • Tyrell Corp
  • Tyrell Corp's Avatar
24 Oct 2015 08:44 - 24 Oct 2015 08:50
#695748
Yes, ignition switch controls head, tail and ignition circuits. easy to miswire or find a pattern switch with the wrong configuration. Look at the box at the bottom of the wiring diagram, it has a truth table that shows the connections between circuits.
Attachment 14457098949197.jpg not found
Ignore the one I posted, just an example -find the correct diagram for your bike. In this example, note the battery is connected to the ignition and headlight only when ignition switch is in the 'on' position.
Was it doing this before the relay mod?
Last edit: 24 Oct 2015 08:50 by Tyrell Corp.
  • JR
  • JR's Avatar
24 Oct 2015 08:58
#695751
jackleberry wrote: You say you did the coil mod... It sounds like the relay you used has failed in the closed position or a couple of the wires have shorted together. Try a new relay.
Please let us knowwhat you find but I would bet on this being the problem. Shorted relay or wired incorrectly. Your ignition circuit is live all the time. Like being "hotwired "
  • New 750
24 Oct 2015 10:32
#695764
Yup that's it! I have not touched anything and the mod has been on the bike for months, it's the relay, and yes battery dies after a while, I can't believe I did not fry the coil, somehow the relay is stuck on.
1977 kawasaki KZ750
  • missionkz
24 Oct 2015 10:41 - 24 Oct 2015 10:42
#695765
Ok. Sounds like you know what to do.
I did not see in the original post that you've operating the bike for months after the relay mod!
In the future try to put more info about when mods were done or how long ago vs when something went wrong. LOL!
Bruce
1977 KZ1000A1
Last edit: 24 Oct 2015 10:42 by missionkz.
  • New 750
24 Oct 2015 11:14
#695767
I put a four pin relay from my minivan in its place and it worked fine, I bought the proper amperage unit per a write up on here, the only thing I can think of it it's exposed to water from time to time, but I would think it should last more then a few months? I was also under the impression that my coils could be fried from constant juice, (assuming the points are closed when shut off) thanks alot for the input, just solved two nagging problems, can't believe I did not check the relay.
1977 kawasaki KZ750
  • jackleberry
24 Oct 2015 11:33
#695769
New 750 wrote: I put a four pin relay from my minivan in its place and it worked fine, I bought the proper amperage unit per a write up on here, the only thing I can think of it it's exposed to water from time to time, but I would think it should last more then a few months? I was also under the impression that my coils could be fried from constant juice, (assuming the points are closed when shut off) thanks alot for the input, just solved two nagging problems, can't believe I did not check the relay.
You can get 40A relays on ebay dirt cheap these days that are, somewhat surprisingly, sealed with epoxy to keep out the elements. You can do this yourself if you get one that not sealed already.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
