Wiring harness for an 81 KZ440
  • MartyrMachine
  • MartyrMachine's Avatar Topic Author
23 Oct 2015 19:37
#695689
I recently ripped mine out. The previous owner had no clue what he was doing. The wiring harness looked like a rats nest, everything was poorly wrapped in electrical tape. It was a nightmare. I decided to go with a simple setup for my bikes electrical system. I'm just going to remove the key ignition, wire the starter solenoid to a button and put a circuit interrupter switch hidden on the bike so you have to switch it on to start it. I don't plan on leaving the bike anywhere besides my garage anyway. Then the headlights will be wired to a switch.
I still need to wire up.
-Headlight/ running lights
-Brake light
-Tach/ speedo
-Maybe blinkers
And then the obvious basic stuff, spark plugs, etc.
Is there a generic/ universal wiring harness I could buy to use? or am I stuck working from scratch? I'm not opposed to it, i've worked with automotive wiring before, I'd just like the easiest option if it's available.
1981 KZ440-b
"Martyr Machine"
  • martin_csr
  • martin_csr's Avatar
Re: Wiring harness for an 81 KZ440
24 Oct 2015 01:19 - 24 Oct 2015 01:21
#695695
Dimecitycycles might have simple wire harnesses. Or you might find a good 440 or universal harness on eebbaayy.
Here's a topic by loudhvx in which he supplies quite a few bare bones wiring diagrams.
KZR topic -- 1980 750H bare bones for mattylight by loudhvx
Last edit: 24 Oct 2015 01:21 by martin_csr.
The following user(s) said Thank You: MartyrMachine
