blown fuse
- nightrider_2961
blown fuse
08 Oct 2015 12:51
i have a 1976 kz900 i been having my main fuse blown 20 amp it will run for a while then blow a fuse
- dom2570
Re: Re:blown fuse
08 Oct 2015 13:06
Check for shorts, clean connections, and make sure everything is getting good airflow.
My 750 kept blowing the main fuse and I couldn't figure out why. One day I was on the side of the road switching out the blown fuse and burned my hand on the ic ignitor. I repositioned it for better airflow and haven't blown a fuse since.
Whip it like a mule!
- eddiem
- KZR FLAG RELAY CARRIER #63
Re: Re:blown fuse
08 Oct 2015 17:34
if you're running dyna coils make sure they are not grounding out on the mounts
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
