82 kz1100a wiring guidance
- rl1062
29 Sep 2015 10:02
My son bought a rolling chassis 82 kz1100a for a project bike and it seems to have become my project. I have it running fine and have been able to find most of the missing parts but I am stuck on the electrical. I am trying to get a starting point for the problem of having no turn signal power and no brake light power. I have confirmed that all the items work with direct power but I am not sure what could cause me to loose them all. Fuses are good but I need to know where to start
- MFolks
Re: 82 kz1100a wiring guidance
29 Sep 2015 11:18
I'd do this before cutting 7 splicing wires:
Cleaning Motorcycle Electrics
Get some of the De-Oxit electrical contact cleaner and figure on spending a good day going from the front of the bike to the back. It’s a plastic safe cleaner/preservative. www.deoxit.com is their website.
On the older Kawasaki's, a majority of electrical connectors are inside the headlight housing requiring removal of the headlight, then the fun begins.
Do one set of electrical connectors at a time to avoid mixing up what connects to where. Usually disconnecting, spraying with De-Oxit and reconnecting is about all you'll need.
However, when encountering the green crud of corrosion, a brass wire brush may be needed on the pins you can reach.
Some 400-600 grit wet and dry sandpaper strips rolled into a tube should reach the male and female pins in the more difficult to clean connectors.
Smoker’s pipe cleaners, cotton swabs and wooden toothpicks work as cleaning aids.
Really small electrical connectors may require the use of a welders tip cleaning tool assortment.
Most pins in the connectors are coated with a thin plating of tin, and others may be nothing more than copper or brass.
If moisture is added, the resulting corrosion lowers the voltage/current being carried causing dim lights, slow engine cranking, slow turn signal response and lower input voltage to the ignition coils resulting in weak spark.
The left and right handlebar switch pods will need attention too as they have circuit functions like turn, horn, run/stop, and start.
Usually a spritz or two with actuation of the switch is about all needed for these switches unless corrosion is detected and then careful disassembly is required.
The ignition switch may or may be not sealed to allow spraying the internal contacts. I urge caution if attempting to open this up as springs, and ball bearings may fly out never to be seen again!
If your bike has the older style glass tubed fuses, I suggest replacing them as vibration can cause internal failure. AGX is the type used, and most auto parts stores can get them for you.
Clean the fuse holder clips, looking for signs of overheating(discolored insulation, signs of melting).
I use metal polish on a cotton swab, followed by spraying another clean swab with the De-Oxit and then rubbing the inside of the fuse clip.
All battery cables must be clean and tight for maximum current transfer. Check the cables going from the Negative(-) battery terminal/post to the engine mounting bolt
Also the one going from the Positive(+) terminal to the starter solenoid and from there to the starter motor.
If any battery cable feels ”Crunchy” when flexed, replace it as possible corrosion is inside the insulation.
Each "Bullet Connector" will have to be sprayed to ensure good connectivity, especially the ones going to the energizing coil of the starter solenoid.
The alternator output “Bullet Connectors” are usually behind the engine sprocket cover and will need inspecting and cleaning too.
The turn signal light sockets will benefit from a spritz from the contact cleaner along with the tail light/brake light socket.
Some brake light switches can be sprayed on the actuating rod, with the spray running down inside to the electrical contacts, others may be sealed requiring replacement if the switch is intermittent in operation.
Some people put the Di-Electric Grease on cleaned terminations/connectors, I don’t, as I’ve read/heard it can cause problems when it gets hot, actually insulating the connections, so the choice is yours to use or not.
Using WD-40?
Bad idea! WD40 is a bad thing to use on wires, contacts, etc.! More than one person on this site has suffered the effects of using it that way. Use Deoxit or some other contact cleaner to clean that WD40 off anything electrical before that WD40 crap sets up and becomes an insulator.
As a matter of fact dielectric grease isn't a great idea either. Dielectric is essentially an insulator for the purposes of conducting electricity. I've spent many hours cleaning dielectric grease out of connections. It heats up, liquefies, then gets wicked into contacts. The contact area that actually carries current then is reduced and heats up more.
Just got done replacing headlight connectors on a Civic. They were full of grease (that looked cooked), and the bulbs were dim. Only chopping off the connectors and replacing them got the bulbs back to full brightness
“I spent a weekend going through every electrical connection and switch on the bike with a little scotchbrite pad and DeOxit - what a difference! Everything was brighter, gauge backlights, indicator lights, turn signals, I was getting a nicer spark, it fired up quicker, etc. Well worth my time. WELL worth it! “
From a forum member at www.kzrider.com
Re: Cleaning the many and various Motorcycle electrics.
I used the De-oxit D-5 spray on all the electrical connections of my 78 Kz1000 that had sat for twenty years .
When I parked the bike in 92 I was starting to have troubles with some of the electrical system, but after pulling everything apart and giving it a spray , reconnecting the connectors and working them back and forth a few times, then gave them another shot of spray to wash them off before the final reconnection.
Everything still works perfectly and has for over 7000 miles this year.
I am extremely happy with the results , a lot of the connectors were green when I started and after the cleaning they looked new ( shiny gold )
I found the Deoxit D-series, D-5 spray in a 4 oz can at a big electronics store called Frys in Illinois, don't get the small cans at Radio Shack , they are different and meant for computer type stuff.
store.caig.com/s.nl/sc.2/category.188/.f
Recommendations:
Excellent contact cleaner from audio to ac power contacts
I've been an A/V Tech-Roadie for over 30 years and have used Deoxit since it was first introduced. I've cleaned /rejuvenated volume controls,switches and audio connections on everything from guitar amps to full blown recording consoles. It not only cleans mild to excessive corrosion but the lubricant keeps the part in good working order months afterwards. Much easier than replacing a hard to replace part. I also spray it on all the audio connectors periodically to insure good connectivity. Along with my A.C. power plugs and quad boxes that are used outside for live shows to prevent corrosion from the elements.
Good stuff. Obviously highly recommended.
Using WD-40?
Recommendations:
- MFolks
29 Sep 2015 11:20
You'll need a good multimeter, for voltage and resistance checking, along with the wiring diagram. If needed, ask, as I've got a soldering repair procedure, as the older bikes are seeing signs of the factory soldering "Jobs" failing.
- rl1062
30 Sep 2015 04:13 - 30 Sep 2015 04:13
I have read the post about deoxit before and will look for some. I have had to figure a lot of this bike out since it was mostly in a box and some things the po touched he should have left alone. All front wiring was disconnected and headlight bucket was missing. Seems bike had a fairing from some of the splits. I found it conspicuous that the turns and brakes both didn't work but horn headlight work and was looking for anything common between them to start my search
Last edit: 30 Sep 2015 04:13 by rl1062. Reason: spellcheck
