Quick KZ400 Battery Question
- Adam970
08 Sep 2015 11:48
I am about to replace the battery on my 78 kz400 and I can't find it in the manual, what are the volt/amp requirements for my starter motor? Thanks,
Adam
Adam
- pete greek1
Re: Quick KZ400 Battery Question
08 Sep 2015 12:03
It would be the same # as your old battery
what model KZ 400 do you have,,A, C, D, ??
look at your old battery for a # like, 12N5-5-4a
Pete
Pete
08 Sep 2015 12:39 - 08 Sep 2015 12:39
KZ400.com
-->> Manual -->> 1978-81 -->> Page 1 - 33 Specs and adjustments.
Yuasa 12N 12A-4A-1 (12V 12 AH).
Last edit: 08 Sep 2015 12:39 by martin_csr.
- Irish Yobbo
08 Sep 2015 21:20
I've always been an advocate for using the biggest battery you can fit. Your CCA or reserve capacity can't be too high - you'll just be paying a little more for it. The way I see it, after a few years and the battery starts getting a bit tired, a bigger battery will still be cranking fine.
I use a 220CCA lithium in my KZ250.
1981 KZ750 LTD
- Adam970
