1980 KZ1000 Resistor assembly needed
  • ellis23
  • ellis23's Avatar Topic Author
07 Sep 2015 16:48 - 07 Sep 2015 16:56
#689066
Hey guys I have a 1980 KZ1000LTD engine...that's it...wires are missing and I am trying to piece together an electrical system to try and see if the engine runs. I have the IC Ignitor unit, two ignition coils, spark plugs and wires, but I haven't been able to find a resistor assembly. Does anyone know where I could find one that would fit my bike or recommend an aftermarket that would work? Most OEM resistors that I have found are back ordered and local parts store haven't been able to help. This is my first project bike so any info helps. Thanks.
Last edit: 07 Sep 2015 16:56 by ellis23.
  • MFolks
  • MFolks's Avatar
Re: 1980 KZ1000 Resistor assembly needed
07 Sep 2015 17:03
#689070
If it were me, I'd contact the resident "Wizard" Loudhvx, and ask him about wiring around it. I don't think it's needed.
  • ellis23
07 Sep 2015 17:30
#689077
I thought about just trying to bypass it but I read somewhere that it could fry the pulsers,
  • ellis23
07 Sep 2015 17:33
#689078
Also, How do I contact the Wizard? I'm new to using forums as well...a lot of firsts for this guy!
  • martin_csr
  • martin_csr's Avatar
08 Sep 2015 04:45
#689120
As expected, the resistor assy is listed as part obsolete at Partzilla. Most parts like that aren't available any more from the Kawasaki dealer or any of the on-line places. I did not see a nos part listed on eebbaayy. There's a used one, but it's in poor visual condition & pricy too. $50T. (#28018-1018).
This may not be much help & I don't know if there's anything for your 1980 KZ1000, but here's a topic with a number of bare bones wiring diagrams provided by loudhvx. 1980 750H bare bones for mattylight
  • retterath
  • retterath's Avatar
08 Sep 2015 07:12
#689144
I have a good used one if you find that you really need/want it.
  • missionkz
  • missionkz's Avatar
08 Sep 2015 08:42 - 08 Sep 2015 08:42
#689161
No eBay APP ID and/or Cert ID defined in Kunena configurationOr, just make your own with a couple 1 ohm or 2 ohm 50 watt power resistors.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Last edit: 08 Sep 2015 08:42 by missionkz.
  • ellis23
09 Sep 2015 02:46
#689264
Yea I called a couple of local dealerships and service shops and they pretty much had no idea what I was talking about...so..they were no help...the first response I received on the forum said that they thought I probably didn't need the resistor...anybody agree? Would resistor spark plugs or resistor caps help me out at all? I appreciate you guys responding...thank you
