Neutral Light Wiring 82 kz550 c ltd
- aarb77
06 Sep 2015 10:41
New Drag 2.5" speedometer with high beam, neutral, oil (which I hooked up for low fuel), and turn signal. All dummy lights wired and running except my neutral light.
The light itself works but when I plug the neutral switch wire into the ground for the light it does not work. Tried a new wire and still nothing.
Also does anyone out there have a color copy of the wiring diagram for the 82 KZ550 C LTD?
RB
Re: Neutral Light Wiring 82 kz550 c ltd
06 Sep 2015 11:55
Did you check the wire connector at the neutral switch?
KZRider loudhvx has wiring diagrams on his motorcycle stuff page. manual & wiring diagram page
- aarb77
Re: Re:Neutral Light Wiring 82 kz550 c ltd
06 Sep 2015 14:05
Female end? Is so yes. I tried a new wire from neutral swith to light ground. It's acting like it's not making a conection on the other side of the cover.
RB
