Here's my bike.. need some help with checking wire
- Turbo99397
06 Sep 2015 08:08 - 06 Sep 2015 08:09Attachment FB_IMG_1436069548606.jpg not found
My title says 1980 kz1000 which kinda assuming police bike? Is this correct.. I'm trying to track down some service information but the bike may or may not have been put together with other bikes. As some of u may know I'm having drivability issues including center 2 cyls quitting. Just figured I'd go thru and check some things before I get too stressed out.... is there any wires under the headlight area I should check? There are so many things I suppose causing issues I want to go thru and check all the electrical first.
Last edit: 06 Sep 2015 08:09 by Turbo99397.
- pete greek1
Re: Here's my bike.. need some help with checking wire
06 Sep 2015 09:41
It's not a police bike, it looks like a 1980 KZ 1000 MK II
if you post your engine & frame # s here, some one can look them up & tell you what you have, so you can get the proper Kawasaki service manual for your year & model bike,
Pete
Pete
- StreetfighterKz
Re: Re:Here's my bike.. need some help with checking wire
06 Sep 2015 11:30
It's a Kz1000E Shaft. No wiring in the headlight area should affect the #2&3 running disorder.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
The following user(s) said Thank You: pete greek1
- kaw-a-holic
06 Sep 2015 12:23
A loose power wire to a coil can. Thats usually under the tank. A lot of models have a single power lead with a dual bullet female connector. A power wire from each coil plugs into it.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
- pete greek1
06 Sep 2015 13:07
Good eye, Doug, ....I had too put my glasses on to see the shaft emblem,
Pete
Pete
