Charging issue/question
- missionkz
Re: Charging issue/question
13 Sep 2015 18:12I don't understand why you are not getting on the bike and riding it just the way it is.Shabba wrote: Sooooooo.... I decided to just remove the new r/r and replace it with the old one simply because the old one was charging enough for me to ride to work and back. My thinking is that I'd rather undercharge or just barely charge enough to get some saddle time in without ruining the battery and possibly other parts of the charging system.
Upon removal and inspection, I noticed that the ground cable from the old r/r, where it attaches to the connector, was loose. As I looked further, it came out completely. No corrosion, no breakage, just where the cable and the metal connector divorced. I pulled the plug out of the plastic, carefully crimped it and put it all back together.
Charging? 13.5 at idle, 13.9-14.2 at 4k rpm. Everything is working too. I checked with the high beams on and as soon as I flicked the high beam on, charging dropped to 12.9 and immediately built back up to 14.0.
Does this sound like it's doable until I can get a high quality r/r?
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
The following user(s) said Thank You: 650ed, Shabba
13 Sep 2015 18:19 - 13 Sep 2015 18:29
+1
I must be missing some piece of the puzzle. It seems like the concern is that at 4,000 rpm 14.2 V is too low but 14,8 V is too high. Considering the specification for the bike states "ABOUT 14.5 V" I wouldn't think either one was a problem. These bikes are pretty old and I don't think the technology in use when they were made was ever intended to keep the voltage at a level within 1/10 of a volt. As long as it doesn't exceed 15 V it is within the specs for at least some KZ models, so the battery isn't going to explode or boil over, and as long as it is charging above 14 V the battery isn't going to go dead. I would just ride the thing and worry about the voltage regulator if the battery went flat or used water at an excessive rate. Ed
Last edit: 13 Sep 2015 18:29 by 650ed.
The following user(s) said Thank You: Shabba
- Shabba
14 Sep 2015 07:20missionkz wrote:I don't understand why you are not getting on the bike and riding it just the way it is.Shabba wrote: Sooooooo.... I decided to just remove the new r/r and replace it with the old one simply because the old one was charging enough for me to ride to work and back. My thinking is that I'd rather undercharge or just barely charge enough to get some saddle time in without ruining the battery and possibly other parts of the charging system.
For the very reason Ed mentions: the bike is 30 years old and my fear is doing damage that will cost much more time than being cautious and trouble shooting.
I rode it to work today and coupled with the cool weather (53 F when I left, Richmond, VA.), the bike was running like a top. I might take the long way home when I leave this afternoon.
Of concern was the puddle under the bike this morning. It seems the battery did indeed get a little warm while I working on it yesterday. I checked the water level and it was fine so I am presuming that was excess. I will be keeping an eye on it. I've also contacted the seller of the new r/r and he is shipping me a new one this week so I will have a spare.
Otherwise, I'm going to ride. This bike is as fun if not more than my Guzzi. That's saying a lot.
-Colin
-82 GPZ750
-15 Yamaha FZ-09
-00 Suzuki TL1000S
-13 Nissan Nismo Juke
-82 GPZ750
-15 Yamaha FZ-09
-00 Suzuki TL1000S
- jackleberry
14 Sep 2015 08:44Shabba wrote:missionkz wrote:I don't understand why you are not getting on the bike and riding it just the way it is.Shabba wrote: Sooooooo.... I decided to just remove the new r/r and replace it with the old one simply because the old one was charging enough for me to ride to work and back. My thinking is that I'd rather undercharge or just barely charge enough to get some saddle time in without ruining the battery and possibly other parts of the charging system.
On a somewhat related note, if/when that battery finally does bite the dust, get yourself a sealed AGM battery. They're much less fuss.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
2001 KZ1000P (P20)
- jackleberry
14 Sep 2015 08:48Shabba wrote: Sooooooo.... I decided to just remove the new r/r and replace it with the old one simply because the old one was charging enough for me to ride to work and back. My thinking is that I'd rather undercharge or just barely charge enough to get some saddle time in without ruining the battery and possibly other parts of the charging system.
If I were you I'd take each spade out of those connectors (R/R side and harness side) one by one and solder them to the wires.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
2001 KZ1000P (P20)
- Shabba
14 Sep 2015 15:10jackleberry wrote:Shabba wrote: Sooooooo.... I decided to just remove the new r/r and replace it with the old one simply because the old one was charging enough for me to ride to work and back. My thinking is that I'd rather undercharge or just barely charge enough to get some saddle time in without ruining the battery and possibly other parts of the charging system.
Good idea. I think I shall do that.
-Colin
-82 GPZ750
-15 Yamaha FZ-09
-00 Suzuki TL1000S
-82 GPZ750
-15 Yamaha FZ-09
-00 Suzuki TL1000S
- loudhvx
15 Sep 2015 04:54
A good clean crimp is better than soldering. Soldering weakens the copper, makes the connection rigid so that it is more prone to breakat the point where the solder ends, and the flux promotes corrosion. There are only a few places that should be soldered (see where the factory used solder) and the connector to the reg/rec is not one of those places. You can get new everything to restore that connection to factory condition.
If 14.2 is the max voltage on the battery, that is about perfect fora warm day.
15v was a spec back in the days of analog meters. Technology has moved on.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Shabba
15 Sep 2015 08:37loudhvx wrote: A good clean crimp is better than soldering. Soldering weakens the copper, makes the connection rigid so that it is more prone to breakat the point where the solder ends, and the flux promotes corrosion. There are only a few places that should be soldered (see where the factory used solder) and the connector to the reg/rec is not one of those places. You can get new everything to restore that connection to factory condition.
I'm not worried about it at this point. I have a new r/r coming to replace the other one (which they let me keep so I might end up clipping that brown wire on the r/r connector to see what happens) and the original one is still charging at 13.8-14 while riding so I'm solid for a little while longer.
When winter comes, I'll probably be riding the Kawi instead of the Guzzi (I might sell the Guzzi if I'm being honest) so at that point, I'll be a little more serious about what happens. I've read a lot about the soldering vs. crimping issue and I've not made my mind up but hey...I'm just going to enjoy it for now.
-Colin
-82 GPZ750
-15 Yamaha FZ-09
-00 Suzuki TL1000S
-82 GPZ750
-15 Yamaha FZ-09
-00 Suzuki TL1000S
- Shabba
05 Oct 2015 06:03 - 05 Oct 2015 06:03
I have a short update. As I have spent the last week or more inside with the rain, I took the time to pull the headlight out and check the wiring. Nothing in particular was out of sorts other than one of the signal grounds fell apart in my hand. I fixed that with a good crimp, cleaned the brown wire which was in pretty good shape (the wiring loom on this bike is in pretty nice shape overall as it looks to have been gone through in recent times) and cleaned the headlight ground. My headlight is a bit brighter but it's not like it was terribly dim to begin with. I'll pull the switch apart this weekend but I seem to have done enough to keep the bike charging at an acceptable 14.8 ceiling at 4k RPM, 13.7-14.3 at idle.
The battery is holding it's liquid well so I think for now, it appears as though my issue is resolved.
-Colin
-82 GPZ750
-15 Yamaha FZ-09
-00 Suzuki TL1000S
-82 GPZ750
-15 Yamaha FZ-09
-00 Suzuki TL1000S
Last edit: 05 Oct 2015 06:03 by Shabba.
