New turn signals
- Fox
New turn signals
04 Sep 2015 00:13
Hello everybody,
I'm a proud owner of a brand bew kz1000 ltd 1978 b2
and a big fan of wrenchmonkees bicycles !
I actually have a problem and ask for your help if possible.
I have buy 4 new turnsignals example (21 watts) to replace the 4 oem parts (23/8 watts).
2 rear turnsignals works perfectly if front turnsignals are nor connected.
When i plug the front ones then all the turnsignals dont blink and the light just stay open. The Turn Signal Flasher Relay don"t work anymore (no sound).
i' think it's because my 4 new turn signals have a to high watts... am i right?
Btw It's not led turnsignals...
If i'm right What is the best solution for me?
- buy a new oem Turn Signal Flasher Relay (because it must work and mine is too old)
- buy a new led Turn Signal Flasher Relay (because it's more strong)
- other solutions ?
Thank you for your help
Regards
Fox
- other solutions ?
Regards
Fox
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
Re: New turn signals
04 Sep 2015 05:15
Is your battery fully charged? You might want to try again with a battery booster connected. A couple watts difference in the lights shouldn't cause the issue you describe. Other than that, it sounds like something is hooked up wrong.
04 Sep 2015 05:15
I have found the Tridon/Stant 552 2 prong turn signal relay to work better than the stock relay. It is electronic, so it does not depend on resistance to make the flashers blink. Even if the battery is fairly low the flashers blink at a consistence rate. For my 1977 KZ650-C1 it was a direct replacement being the exact same size and shape as the original. Pretty much any car parts store sells them, and like me, they are cheap. :laugh: Ed
The following user(s) said Thank You: Fox
- Fox
04 Sep 2015 20:35
Hello,
Ok
Because my battery is new, I will try with a new electronic turn signal relay.
I will post the results when i got it.
Thank you,
Fox
Ok
Thank you,
Fox
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
- Fox
08 Oct 2015 13:27
No eBay APP ID and/or Cert ID defined in Kunena configurationHello,
I finally receive my new flasher relay
But it don't resove the trouble.
Back turn signals are working perfectly alones.
But when i install the 2 front ones the turn signals just stay open and don't flash anymore.
(the flasher relay don't work anymore = no sounds)
Do you have an idea?
Regards
fox
Regards
fox
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
- Fox
11 Oct 2015 01:18
Yes i finally find the trouble. It's a wiring trouble.
I need a picture or a draw to instal this corectly on my bike
Someone can help?
Regards,
Fox
Someone can help?
Regards,
Fox
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
11 Oct 2015 01:53
The wiring diagrams are in your manual. If you don't have one you need to get one.
- jeffo
Re: Re:New turn signals
11 Oct 2015 14:21
www.kzrider.com/filebase/category/94-kz1000-electrical
Or just look here:Fox wrote: Hello,
Someone can help?
Regards,
Fox
1981 KZ650H1 CSR
- Fox
14 Oct 2015 03:16 - 14 Oct 2015 03:17
Hello,
Ok i find some cables troubles and repair them.
The turnsignals was working perfectly and warnings too
I test the motorcycle and run a little.
Then i test my turnsignals : good.
I test the warnings : nothing.
I insvestigate more and finaly find something : The warnings are working just if the left or right turnsignal button is open...
If the turnsignals button is off i can't have warning...
Not a big trouble ... But if someone have an idea.
Fuses are OK.
Relay is new.
-Last time when i try to have the warnings i ear the relay sound one time... and nothing.
- My new front turnsignals have 2 cables. Oem ones have 3 cables. So the bleu ones on the headlight (one for each front turn signals) are not connected.
Fuses are OK.
Relay is new.
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
Last edit: 14 Oct 2015 03:17 by Fox. Reason: front
- MFolks
15 Oct 2015 18:02
Color Codes On Most Kawasaki’s (written for 1980’s bikes)
HEADLIGHT
RED with BLACK stripe, High Beam.
RED with YELLOW stripe, Low Beam.
BLACK with YELLOW stripe, the ground circuit.
BRAKE/TAIL LIGHT Can be an # 1157 dual filament bulb
RED, Running or Tail Light.
BLUE,(sometimes with a Red stripe) Brake Light Circuit.
LEFT FRONT TURN SIGNAL Can be an #1157 dual filament bulb
GREEN, Left front turn signal circuit.
BLUE, Left front running light circuit.
RIGHT FRONT TURN SIGNAL Can be an # 1157 dual filament bulb
GREY, Right front turn signal circuit.
BLUE, Right front running light circuit.
LEFT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREEN, Left rear turn signal circuit.
RIGHT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREY, Right rear turn signal circuit.
Most front signals, had duel(2) filament bulbs, a running, and turn signal. The rear signals were just that, no running lights.
HEADLIGHT
The following user(s) said Thank You: NHenneous, Fox
- Fox
17 Oct 2015 01:05
Hello,
thank you very much.
Now i can confirm that all my wiring is correct
Well, everything is working... i just have to activate left or right turnsiganls button to have warnings....
In the same time i can see low intensity headlight when i use turnsignal, and more low intensity when i use warnings.
But battery is new.
But battery is new.
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
