Speedo & Tacho swap.
- yorkieUK
26 Aug 2015 02:16
Does anyone know if I can make the white speedo & tacho from a KZ C3 fit my KZP-9?
1982 GPZ1100 plunger chop
1990 KZ1000P-9 (ex San Diego P.D.)
- Tyrell Corp
Re: Speedo & Tacho swap.
26 Aug 2015 08:10
Not quite sure what clocks you are referring too, other than if you can make it physically fit, the speedo gearboxes are all the same ratios I believe, and if you are going to an electronic tacho from cable driven then just pick a pulse wire to the tacho -usually black, from one of the coil -ve wires.
You may need to change / reconfigure the block connector, oem Hitachi mini block connectors are available on ebay uk.
KZ C3? the KZP-9 is a police mk 9?
The following user(s) said Thank You: yorkieUK
26 Aug 2015 08:25 - 26 Aug 2015 08:30
KZ C3 = 1980 KZ1000-C3 Police ......... KZP-9 = 1990 KZ1000-P9
From the diagrams at partzilla:
The C model has a cable driven tachometer. The P has an electronic tach.
Last edit: 26 Aug 2015 08:30 by martin_csr.
The following user(s) said Thank You: Tyrell Corp, yorkieUK
- yorkieUK
26 Aug 2015 11:10
Any thoughts on just swapping the clock faces? I think the white ones look so much better on the police bikes.
- Tyrell Corp
26 Aug 2015 11:38
No eBay APP ID and/or Cert ID defined in Kunena configurationYou might be able to get some new custom faces made up, there are companies advertising online. Also you get 150 mph clocks.
Clocks are usually quite in demand so it would be a shame to trash a decent set just for the faces.
Msybe have a chat with these, if they have a low minimum order maybe knock a few sets out and sell them your self.
