Coil for a KZ305
- happyhunter
Coil for a KZ305
23 Aug 2015 20:02
So my 82 KZ305CSR is out of commission. My 20 year old son left the ignition switch on overnight drained the battery and the coil for the left cylinder is now dead. I found several coils for GPZ305s on ebay. I hear you can remove the plug wire and change the length of it. Can this be done? How do I do this? Do I have any other options? Or do I have to hold our for a left side coil with the long plug wire?
Thanks,
HH
Thanks,
HH
'82 Kawasaki KZ305CSR
I did not set out to buy a project bike,
but I got one anyway.
- JR
Re: Coil for a KZ305
24 Aug 2015 05:52
Take a close look at your coil. If there is a knurled collar where the plug wire enters the coil then this can be unscrewed and the wire removed and replaced. If no collar then google "ngk wire splice" which should be easy to find
24 Aug 2015 06:14 - 25 Aug 2015 05:34
[strike]Most 80s models with electronic ignition have the ribbed compression boots, so you can easily remove/cut/replace the spark plug wires. [/strike]
Edit: I had assumed your bike had electronic ignition, but from the diagrams the 82 305-B1 CSR has points, and the spark plug wires are molded into the coils & cannot be removed. Z1Enterprises.com sells spark plug wire splicers.
Last edit: 25 Aug 2015 05:34 by martin_csr.
- happyhunter
25 Aug 2015 03:58
No eBay APP ID and/or Cert ID defined in Kunena configurationI am looking at this on ebay:
I think it would work. But, it only has one terminal to wire up??? How does that work? Wouldn't it need +12V and the points connections?
Thanks,
HH
Thanks,
HH
25 Aug 2015 05:26 - 25 Aug 2015 05:27
The 87 GPz305 has electronic ignition (pretty sure), so those coils probably aren't suitable for points ignition.
I wouldn't buy old used coils. Just an FYI: you might be able to convert your bike to electronic ignition.
Last edit: 25 Aug 2015 05:27 by martin_csr.
- GPz550D1
25 Aug 2015 09:26
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationDid you see these two NOS Kawasaki coils on ebay. These are both correct for your '82 305CSR LH.
1981 KZ550-D1
- happyhunter
26 Aug 2015 15:17
No eBay APP ID and/or Cert ID defined in Kunena configurationI did see them, a bit pricey for me. I ordered this one:
It should be here Monday.
Thanks!!
HH
Thanks!!
HH
