Starting issues. Coils the cause?
  • Gordy
  • Gordy's Avatar Topic Author
16 Aug 2015 08:58 - 16 Aug 2015 09:13
#685949
I'm having issues with my Z650 1978 it has been cutting out and now won't spark. It has just been rejetted and had the carbs sync'd so I don't think the issue is there.
I took the spark plugs of and I'm getting an orange spark by the look of it. I've taken a multimeter to the primary and secondary parts of both coils. The secondary coils on both coils aren't showing any resistance value on the 200k settings on my muitimeter. I tried bypassing the spark plug lead and testing the resistance on the coil directly with the same result. I've cleaned the connectors with a sanding pad to get rid of any crud or issues. I also checked the voltage going into the coils this was reading 10.5v when the ignition was on.
I was about to order some new coils, but before I do I want to make sure I'm not missing something. It seems odd for both coils to fail?
Is there anything I should test for? Is there anything that could have caused this to happen?
Should I order a set of the dynatek ones or are there better choices?
Last edit: 16 Aug 2015 09:13 by Gordy.
  • loudhvx
  • loudhvx's Avatar
Re: Starting issues. Coils the cause?
16 Aug 2015 10:17
#685955
If the coils are original, they will have tiny cracks in them. They will work ok for years with the cracks, but if they get wet, they can suddenly become troublesome, or quit entirely. This is why coils may often both go bad at the same time. Have you ridden in the rain within the last 100 miles or so?
Either way, if they are original coils, they are beyond the normal life expectancy already.
The following user(s) said Thank You: Gordy
  • MFolks
  • MFolks's Avatar
16 Aug 2015 10:19
#685956
What's the input voltage to the ignition coils? It should be close to battery voltage(depends on other circuit draw, if the battery is weak).
Ignition Coil Primary And Secondary Wiring
Ignition coils on the 80’s Kz1000,Kz1100’s and Gpz1100’s are wired the same, that is as you sit on the bike, the LEFT ignition coil primary(small wires) are two wires, RED and BLACK. The secondary (or sparkplug wires) go to #1 and #4 sparkplugs(your primary wiring may be different).
Read carefully, as the 550’s, 650’s, 700’s & 750’s are backwards to what is listed for the bigger 4’s.
The cylinders are numbered left to right as you sit on the seat; #1,#2,#3, and #4.
For the RIGHT ignition coil, the primary wires, again are two wires, RED and GREEN, with the secondary going to #2 and #3.
The RED wire gets it’s voltage from the run/stop switch on the right handlebar switch pod. Your primary wiring may have a different color.
The BLACK and GREEN wires connect to the IC Igniter(if the bike has the Kawasaki supplied electronic ignition) it actually gives the coils their grounds to fire the sparkplugs. The RED wire is common to both ignition coils.
Primary(small wires) side of the coils will read between 1.8 to 3.0 ohms.
Secondary(sparkplug wire ports)side of the coil will read between 10.4K to 15.6K ohms. These ports are wired together, so it makes no difference which is used, as long as the correct coil to sparkplug configuration is followed.
The sparkplug caps should read 5K OHMS(5000), any higher, or a reading of infinity means new caps should be ordered. When re-installing the old or new sparkplug caps, cut about ¼” off the sparkplug wires for a new un-corroded connection.
Never run supression sparkplug wires with sparkplug caps containing the 5000 ohm resistor, as now there will be two (2) resistances in the ignition coil’s secondary circuit, causing weak and intermittent spark.
To stress the ignition coils, take a hair dryer, heat the coils and see if the ohm readings change from cold to hot . If they do, it’s time to buy new coils.
Keep in mind, the wiring is reversed for the 550’s, 650‘s,700’s, and 750‘s, that is the RIGHT coil primary will be two wires, RED and BLACK with the secondary(sparkplugs) going to #1 and #4.
The LEFT coils primary wiring would be again two wires, RED and GREEN, with the secondary(sparkplugs) going to #2 and #3.
An indication of black and sooty sparkplugs may not mean a carb or carbs are in need of cleaning, but may mean the input voltage is low.
When checking the input voltage to the ignition coils, first have a fully charged battery, and the using a multimeter, set it up to measure VDC(Volts, Direct Current), range of 20.
Put the RED probe from the multimeter on the same terminal that either a RED wire or ones that’s RED with YELLOW stripe, and the BLACK probe on either a good frame/Earth ground or the battery Negative(-) terminal/post.
Depending on the motorcycles current draw( lighting, and other high amp needs) the reading might be 10 volts or more, but if the reading is down around 8 volts or less, this indicates a corrosion or wiring problem needs correcting to improve input voltage to the coils.
These engines have what is known as a “Wasted Spark” that is, a sparkplug will fire during an exhaust stroke. It does no damage and many other motorcycle engines have this design.
  • MFolks
  • MFolks's Avatar
16 Aug 2015 10:24
#685958
Cleaning Motorcycle Electrics
Get some of the De-Oxit electrical contact cleaner and figure on spending a good day going from the front of the bike to the back. It’s a plastic safe cleaner/preservative. www.deoxit.com is their website.
On the older Kawasaki's, a majority of electrical connectors are inside the headlight housing requiring removal of the headlight, then the fun begins.
Do one set of electrical connectors at a time to avoid mixing up what connects to where. Usually disconnecting, spraying with De-Oxit and reconnecting is about all you'll need.
However, when encountering the green crud of corrosion, a brass wire brush may be needed on the pins you can reach.
Some 400-600 grit wet and dry sandpaper strips rolled into a tube should reach the male and female pins in the more difficult to clean connectors.
Smoker’s pipe cleaners, cotton swabs and wooden toothpicks work as cleaning aids.
Really small electrical connectors may require the use of a welders tip cleaning tool assortment.
Most pins in the connectors are coated with a thin plating of tin, and others may be nothing more than copper or brass.
If moisture is added, the resulting corrosion lowers the voltage/current being carried causing dim lights, slow engine cranking, slow turn signal response and lower input voltage to the ignition coils resulting in weak spark.
The left and right handlebar switch pods will need attention too as they have circuit functions like turn, horn, run/stop, and start.
Usually a spritz or two with actuation of the switch is about all needed for these switches unless corrosion is detected and then careful disassembly is required.
The ignition switch may or may be not sealed to allow spraying the internal contacts. I urge caution if attempting to open this up as springs, and ball bearings may fly out never to be seen again!
If your bike has the older style glass tubed fuses, I suggest replacing them as vibration can cause internal failure. AGX is the type used, and most auto parts stores can get them for you.
Clean the fuse holder clips, looking for signs of overheating(discolored insulation, signs of melting).
I use metal polish on a cotton swab, followed by spraying another clean swab with the De-Oxit and then rubbing the inside of the fuse clip.
All battery cables must be clean and tight for maximum current transfer. Check the cables going from the Negative(-) battery terminal/post to the engine mounting bolt
Also the one going from the Positive(+) terminal to the starter solenoid and from there to the starter motor.
If any battery cable feels ”Crunchy” when flexed, replace it as possible corrosion is inside the insulation.
Each "Bullet Connector" will have to be sprayed to ensure good connectivity, especially the ones going to the energizing coil of the starter solenoid.
The alternator output “Bullet Connectors” are usually behind the engine sprocket cover and will need inspecting and cleaning too.
The turn signal light sockets will benefit from a spritz from the contact cleaner along with the tail light/brake light socket.
Some brake light switches can be sprayed on the actuating rod, with the spray running down inside to the electrical contacts, others may be sealed requiring replacement if the switch is intermittent in operation.
Some people put the Di-Electric Grease on cleaned terminations/connectors, I don’t, as I’ve read/heard it can cause problems when it gets hot, actually insulating the connections, so the choice is yours to use or not.
Using WD-40?
Bad idea! WD40 is a bad thing to use on wires, contacts, etc.! More than one person on this site has suffered the effects of using it that way. Use Deoxit or some other contact cleaner to clean that WD40 off anything electrical before that WD40 crap sets up and becomes an insulator.
As a matter of fact dielectric grease isn't a great idea either. Dielectric is essentially an insulator for the purposes of conducting electricity. I've spent many hours cleaning dielectric grease out of connections. It heats up, liquefies, then gets wicked into contacts. The contact area that actually carries current then is reduced and heats up more.
Just got done replacing headlight connectors on a Civic. They were full of grease (that looked cooked), and the bulbs were dim. Only chopping off the connectors and replacing them got the bulbs back to full brightness
“I spent a weekend going through every electrical connection and switch on the bike with a little scotchbrite pad and DeOxit - what a difference! Everything was brighter, gauge backlights, indicator lights, turn signals, I was getting a nicer spark, it fired up quicker, etc. Well worth my time. WELL worth it! “
From a forum member at www.kzrider.com
Re: Cleaning the many and various Motorcycle electrics.
I used the De-oxit D-5 spray on all the electrical connections of my 78 Kz1000 that had sat for twenty years .
When I parked the bike in 92 I was starting to have troubles with some of the electrical system, but after pulling everything apart and giving it a spray , reconnecting the connectors and working them back and forth a few times, then gave them another shot of spray to wash them off before the final reconnection.
Everything still works perfectly and has for over 7000 miles this year.
I am extremely happy with the results , a lot of the connectors were green when I started and after the cleaning they looked new ( shiny gold )
I found the Deoxit D-series, D-5 spray in a 4 oz can at a big electronics store called Frys in Illinois, don't get the small cans at Radio Shack , they are different and meant for computer type stuff.
store.caig.com/s.nl/sc.2/category.188/.f
Inside the sparkplug caps, is a non serviceable 5000 ohm resistor, used to reduce the RFI when the sparkplugs fire. This goes bad from heat, vibration, and age. New ones are available at the local Japanese motorcycle shops. or www.z1enterprises.com . When replacing the caps, cut off 3/16" to 1/4" off the end for a fresh connection & install the new caps.
  • Gordy
16 Aug 2015 11:17
#685965
loudhvx wrote: If the coils are original, they will have tiny cracks in them. They will work ok for years with the cracks, but if they get wet, they can suddenly become troublesome, or quit entirely. This is why coils may often both go bad at the same time. Have you ridden in the rain within the last 100 miles or so?
They are aftermarket replacements by the look of them, as the holes don't line up to the exiting mountings. There is no cracking.
Interestingly despite the secondary coils fail readings the bike fired up first time just now. I think cleaning and checking all the connectors was enough in the short term. I see some new coils and spark plug leads in my future though.
  • Gordy
16 Aug 2015 11:24
#685967
MFolks wrote: What's the input voltage to the ignition coils? It should be close to battery voltage(depends on other circuit draw, if the battery is weak).
Thanks for all the info.
The battery is less than 12months old and fully charged off a trickle charger. It's reading 12.4v and the coils input voltage is reading 10.5v so there is a fair bit of loss in the system somewhere.
I have done a fair bit of your electrical guide already as well as removing/replacing a lot of the loom already. The ignition circuit is not part of that so it seems there is some more work for me there.
  • wex652
  • wex652's Avatar
17 Aug 2015 02:10
#686042
I would recommend you do the 'Wired George' mod'
www.wgcarbs.com/index.php/using-joomla/e...-categories/89-coils
Brian
Brian
Z650B1
17 Aug 2015 03:23
#686046
Old, hard, cracked, worn-out spark plug wires can allow leakage of high tension voltage.
Ideally, full battery voltage (as measured between the battery posts) should be received at the primary terminal on each ignition coil.
Diminution of voltage between battery and coil may occur at one or more of several connections, each of which should be checked for 100% conductivity.
Good Fortune! :)
17 Aug 2015 03:50
#686048
How long has it been since you replaced the points and condenser? Ed
  • Gordy
17 Aug 2015 09:44
#686081
Patton wrote: Old, hard, cracked, worn-out spark plug wires can allow leakage of high tension voltage.
Good Fortune! :)
I've started stripping down the wiring to this part of the loom. I've found some terrible connectors so I'm starting to replace them. I also found this
It looks like a previous owner replaced the ignition system with a Boyer Bransden one. I will be attacking things tonight hopefully.
