MOTOGADGET M-UNIT BOX // KZ400 diagram
  • Kodymadro
  • Kodymadro's Avatar Topic Author
31 Jul 2015 14:28
#683639
My first topic on this was earlier this summer. I started using the M-unit on some of my builds. i have since done a few and have it down pretty good but figured i make a thread with a diagram a made and any info that any one installing this might come across...
MOTOGADGET makes some pretty rad stuff if you're doing a cafe build and want to go for that really clean look with some updated tech... They make the M-UNIT which is a no brainer if you are rewiring your kawasaki... dumbs down the whole process into a user friendly wiring experience (we all know what a headache it can be)!!
Here is a wiring diagram for the Kawasaki KZ400
Revival cycles is the main US online dealer for Motogradget.
REVIVAL CYCLES
Here is my original thread.
www.kzrider.com/forum/4-electrical/59795...it-conversion-wiring
Hopefully this is helpful-Kody
  • diggerdanh
  • diggerdanh's Avatar
Re: MOTOGADGET M-UNIT BOX // KZ400 diagram
03 Aug 2015 08:24
#684051
Thanks for posting this, I'll be wiring up a 78 KZ400 later on this year and haven't determined if I'll try to re-use the factory harness, strip it down and replace as necessary or go complete custom. This may sway me.
Which KZ400s have you done? Earlier (74-76) or later? And which does this schematic apply to? Wondering about the differences in stator and regulator/rectifiers.
  • Kodymadro
28 Aug 2015 00:20
#687435
sorry for the late reply. This applies to the bikes with the regulator/rectifier combo. I made this Diagram off my 79'
  • Turod2g
  • Turod2g's Avatar
02 Nov 2020 06:19
#838131
I have a 75 kz400 and also installed a m unit basic but am having trouble getting the starter to spin. when I hit the start button all I hear is the solenoid click but no power gets to the starter. I tested the starter and it works. Also Im not sure if I have the ignition correct. I wired the yellow/red wire coming out of the coils to the ignition of the m unit and the black wire coming out of the coils left it alone which goes to the points. I see that in your diagram the coil is wired to itself with the brown wire? Can you explain this. I would really appreciate some help guys.
Thank you
  • richard-GPZ
  • richard-GPZ's Avatar
07 Nov 2020 11:50
#838211
You might want to check the state of your stand input. It will keep you from starting if the m-unit thinks the stand is in the up position.
1983 GPZ-1100 completely stock
1983 Gpz-1100 hot rod build in process
  • F64
  • F64's Avatar
  • 81-KZ440D2
07 Nov 2020 18:10
#838228
Hi Richard,
Turod2g figured it out.. The post was deleted because of site maintenance.
It was a disconnected starter cable.
81-KZ440-D2.
LIC, NY
