Project bike,,, No fire.... 81 kz750 four cly
- jcurriert
29 Jul 2015 20:08
Got this project started.... in a day or so my new batt will be here,,,, and I will be trying to diagnose a no fire issue.
Looking for info and help on how to test:
1: Regulator (seen in pic)
2: Coils 1 & 2 (pic takin from left side of bike)
3: Pickup coils ?? not sure where??
-Black 1981 KZ750 LTD (Sold)
-Met. Blue 1982 KZ750 LTD(currently fixing)
-Blue 1982 KZ750 LTD parts bike (parting out)
- azman857
Re: Project bike,,, No fire.... 81 kz750 four cly
29 Jul 2015 20:23
Pickups are on the Rt side crankcase where the crankshaft end is. It's where the points used to be.
- kz n az
29 Jul 2015 21:36 - 29 Jul 2015 21:55
Im no expert but I noticed on my 750 4cl my coil wires are not wired like yours.
Mine are left side red wire bottom of coil and right side red wire top of coil
red leads go to ( + )
green and black to ( - )
( I believe the left one is wrong ---- page 76 in my clymer )
But asked the Expert
Last edit: 29 Jul 2015 21:55 by kz n az.
29 Jul 2015 21:51
The Kawasaki Factory a service Manual covers thse diagnostics and a lot more. It will be the most important tool you buy for this project. Avoid the aftermarket manuals, get the genuine Kawasaki one.
30 Jul 2015 05:48 - 30 Jul 2015 06:50
Here's a site w a pdf manual & wiring diagrams.
mbsween. bike-night. KZ750L3 page
Scroll down & click "The Bible" link. Note: some of the wiring diagrams are mislabeled in the links.
The 1981 Ltd is an H2, the 82 is an H3, & the 83 is an H4. .... search tags mbsween KZ750L3.
The bike needs a good, fully charged battery to run right.
If the voltage regulator is shot, you can install one from a late model Ninja 500 or Vulcan 500 et al (loudhvx).
The manual has resistance checks for the ignition coils which can test fine cold, but they could still need replacing.
If there's a high speed miss, stop & feel the coils, press hard with your fingers --- they should be warm, not hot. The grey Dyna 2.2 ohm coils are the best match for the stock electronic ignition, but you can use the green 3.0 ohm.
Right side coil = #1 & #4 spark plug wires. red & black primary/igniter wires.
Left side coil .= #2 & #3 spark plug wires. red & green primary/igniter wires.
The stock coils are embossed with (+) & (-), but I don't think it matters.
Last edit: 30 Jul 2015 06:50 by martin_csr.
