ZN700 LTD Spark Plug wire questions
- Delusional3
24 Jul 2015 13:40
Alright, I just picked up an '85 ZN700...and it runs..all four cylinders even!
One thing I'm going to do now (carbs, forks, all that fun stuff is this winter), is replace the plugs and wires.
As it sits, there's two sets of two different plugs, and two sets of two different boots/wires....all of which appear to be the same age as the bike lol.
Does anyone have any idea what a good replacement set of wires would be, or where to get/make them? I've got no issue with DIY'ing a set if needed - I'd just have to find a guide.
Thanks ya!
Thanks ya!
Re: ZN700 LTD Spark Plug wire questions
24 Jul 2015 16:47
Z1 Enterprises sells 7mm copper core ignition wire and NGK plug caps. I used both on my 750E. The caps and wires unscrew from their mating parts. If you are careful you can even remove the outer wire sheath from your existing wires and install that over your new wires. That's what I did anyway.
