- Thank you received: 38
Connection to Neutral Switch
- ezrider714
15 Jul 2015 08:59 #680993
by ezrider714
78 KZ650SR Mine since 79
4-1 Mac Jet Hot coated since mid 80's
Dyna Coils
Saddlebags (I ain't skeered of going nowhere)
Connection to Neutral Switch was created by ezrider714
Can anyone point me to a source for the push on type of end connector that connects the wire to the neutral switch down near the sprocket
Can't seem to find a P/N for it, so that is making searching for one even more difficult Or maybe an ingenious way to keep this wire on the switch, I can take my left side apart in my sleep :dry:
Any help would be greatly appreciated
78 KZ650SR
EZ
78 KZ650SR
EZ
Dyna Coils
- Thank you received: 1656
15 Jul 2015 09:16 - 15 Jul 2015 09:17 #680996
by martin_csr
Replied by martin_csr on topic Connection to Neutral Switch
my mistake. wrong type of flag terminal.
Last edit: 15 Jul 2015 09:17 by martin_csr.
- ezrider714
23 Jul 2015 20:55 #682457
by ezrider714
Dyna Coils
Replied by ezrider714 on topic Connection to Neutral Switch
Well Thanks for the help, I know I've seen post regarding terminals for bikes, however Search can't seem to find them???? :dry:
So I had to sort thru a couple dozen wiring harnesses, :blink: I had stuffed away and lo and behold 1 of them had the required terminal, so fixed bike this time. :woohoo:
However I'd like to have a source for terminals for future issues :sick:
Dyna Coils
23 Jul 2015 22:20 - 24 Jul 2015 06:37 #682471
by martin_csr
not sure what that terminal is called --- my first guess was that it might be a type of flag terminal.
The only thing I found was at J&P Cycles, but it's for a harley, V-Twin Neutral Switch Terminal
2009 EX500 neutral switch terminal. I guess the KZ doohickey is the same:
Last edit: 24 Jul 2015 06:37 by martin_csr.
