Fuel pump
- Drewdub
Fuel pump
10 Jul 2015 22:31
Hey guys and gals, I have a 1984 gpz 1100 (USA). Im sorta rebuilding it. Tore it apart fixing the fram and such. Put it all together and BAM. fuel pumps not kicking on. Never had a problem with it before. Checked all my electrical. Not getting any signal to the pump. Fuses all good, I think I got everything together RIGHT. the diagram I have is pretty hard to see so I marked everytbing, but some things got smugded off and such.. Any ideas?!
- MFolks
Re: Fuel pump
11 Jul 2015 09:55
Check the wiring going to and from the fuel pump relay, as the relay powers the pump. Look for broken wires, or corrosion in the electrical connectors, at the relay and pump.
- Drewdub
Re: Fuel pump
11 Jul 2015 10:00 - 11 Jul 2015 10:01
Which ones the relay?
It cranks and cranks. I have 4.2 volts to from the fuel pump connector. You
Last edit: 11 Jul 2015 10:01 by Drewdub.
