Fuel Gauge Light Socket - Z1-R
  • weales
  • weales's Avatar Topic Author
06 Jul 2015 17:10
#679737
Looking for a connector for the bulb which
backlights the fuel gauge on my '78 Z1-R.
The one on mine has been chopped off and lost by some FW PO!
Attached is a pic of the underneath of the fuel gauge to show the sleeve type socket where the bulb connector slides into.
Current Project
1968 Norton P11A Desert Sled
Other bike (and daily ride)
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
  • weales
Re: Fuel Gauge Light Socket - Z1-R
06 Jul 2015 17:24
#679741
This connector is part of the "meter socket ass'y" but if someone has a trashed harness then I'd be interested in buying it for this part.
Attached is a pic of the corresponding bulb and connector which backlight the Ammeter - slightly different as it has 2 wires , one for the power and the other earth. The fuel gauge connector is different - it gets its earth from a wire to the frame which connects to the body of the ammeter and just has the powere wire. I can adapt an ammeter lead & connector if someone has one I can use.
Attached is a pic of the ammeter lamp connector.
Current Project
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
  • Copbike1000
  • Copbike1000's Avatar
  • Banned
  • Banned
02 Nov 2015 19:43
#696968
Wondering if this might work for you......
www.z1parts.net/product/meter-light-z1
  • weales
03 Nov 2015 11:09
#697052
Looks like it might be a cheap and handy option - thanks!
I designed an alternative using a LED in a rubber socket to replace the fuel gauge backlight only.
(If I need to replace both the fuel gauge and ammeter backlights I'll keep this in mind.
Current Project
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
03 Nov 2015 11:40
#697060
crafty lil bugger now ain'tcha!?
  • weales
03 Nov 2015 12:12
#697064
I ran out of patience trying to source a replacement or alternative for the sleeve style lamp.
Tried many Pommy and Japanese bike and car parts suppliers, wreckers etc but NBG!
Tried a range of LEDs - size, brightness, colour and lens angle until I got one to match
the light output of its buddy in the ammeter.
LEDs are very cheap, low current, very durable and very reliable.
Current Project
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
  • Copbike1000
  • Banned
  • Banned
03 Nov 2015 17:10
#697097
Like that LED option. Very nice handy work.
  • weales
03 Nov 2015 17:36
#697102
Also, lots of LEDs come already fitted with a suitable current limiting resistor for 12Volt operation.
All you have to do is connect the flying leads on the LED to your existing harness or crimp on
some open barrel connectors and you're in business! May need to splice thicker wires to the
flying leads to enable a good crimp onto the leads.( I didn't and still managed to get good crimps.)
Just need to observe the LED's polarity otherwise it won't light up when the 12Volts is applied.
Also, if using a Male/female open barrel or "bullet" terminal to make the connection,
make sure the supply side of the connection is a female.
That way if the connector comes apart then there is less chance of the supply shorting to something.
Current Project
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
